- Thread starter
- #61
needing the choke pulled out to run smooth certainly indicates too lean. Should have enough adjustment on the mixture screw to go well past the recommended setting to see if you are able to get smooth idle at least on the 45s . The fact you get back firing under constant load higher in rpm range suggests it is not so far off on lower end but gets too lean higher in rev range under load. The 55 idle jets will make it richer overall. But, the fact it was behaving the same way with the previous carb is odd.
some more thoughts:
Float should adjust for full open stop and also for needle valve seated positions. Too low a float setting for seating the needle valve will make the carb run leaner as fuel level gets lower in the main jets. Most needle valve issues in webers seem to be from going rich with no pressure regulator/too high fuel pressure.
is the gas tank venting or do you get vacuum in the tank under load?
Is the cam timing correct (marks aligned when you were reassembling engine)?
do you get full valve lift on all cylinders (no worn lobes)?
compression numbers ok?
condition of pcv valve and check valve on the brake booster? no other vacuum leaks?
Thanks Martin. The carb backfiring with the 38 / 38 has stopped after removing sediment from the filter. Still have a lean problem but running 45's in the idle jet. Need 60's. Working on it.
Boaf
