Just a suggestion for anyone trying to work with these things-
Start with the stupid basics - such as a true compression test both hot and warm. Record those numbers and when you ask questions let us know the true engine condition as well. Most times a Weber is installed to try to solve a weak engine issue - changing carbs will actually make it worse as the Weber is truly more sensitive to tuning. The Weber is a carburetor kit - not a Band-aid.
If you own a Weber - you'd better have a vacuum gauge, period. Bouncing vacuum readings at idle, low vacuum with stock cams and such are symptoms of a bigger problem - number one issue is almost always a vacuum leak in those junk adapters, others are worn valves, shot rings/pistons and valve guides as well as cracked manifolds or gaskets. This is why I wouldn't do Cruiser conversions - the adapter kits are a joke, let alone trying to properly adapt the throttle system without destroying the carb in short order. For those that have been running a Weber on a Cruiser and have slowly developed a problem with idle position or off-idle response - I'll bet you've worn out the throttle bore on the primary side at minimum. The telltale sign is a lack of idle control and stumbling off-idle, due to leakage at the throttle shaft and primary bore wear. If you can't idle the engine down to around 300 revs smoothly - you have a problem.
The other real tool needed is a timing light with a dial back feature. You must be able to see if the vacuum advance is working, how far it moves (wear issues) and the static base timing. Plus, knowing if the distributor is honestly advancing the ignition timing as it should or not - many are gummed up and need rebuilt. These parts are old, keep that in mind and without everything working together you will waste your time trying to tune the engine for the expected performance. The carburetor itself is one very small part a much bigger system - it all must work together properly as a unit.
Some of the tuning stuff is really not for an amateur, no offense intended nor am I trying to lecture. Without a true mechanic's knowledge of how systems work, how to rebuild and repair all of these parts makes it almost impossible for a common person to work on this stuff. Mechanical distributors, carburetors and internal engine parts are nothing to laugh at - back in the day it was a long process of schooling and teaching mechanics on how to work on these things. Without years of experience, you have to start with the basics and learn from there. Yeah, there are those willing to share their knowledge, the internet can also help, but in the end you have to learn yourself how to diagnose things and find a solution. Most people that get on the internet are looking for the magic solution - it doesn't exist. Most problems with these things are many layers of sub-par system parts that have failed to work to specification. You end up lost and frustrated and blame one part - that is almost never the case - it is total of many issues that created the problem and without fixing all of them you are wasting your time.
There are bore differences in the Chinese knockoff carbs in relation to the jets - the common Italian made jets will not fit. Some of the older Holley generic jets may work, but they also may leak, which is a problem.
I highly suspect you have a knockoff carb, it is not easy to tell the two apart visually unless you really know them. Very few people own Genuine Italian Weber DGV series carbs - I've only ever had a few come through the shop over all the years I did them. Almost all are the later Redline units produced in Spain - so in all honesty, not the real-deal here. All of the screwing around by aftermarket vendors led to the Chinese knockoffs and now Redline substituting the junk Solex for real Webers - and charging the premium price to boot, what a joke.
And folks wonder why I got out of the business..
Sarge
