- Joined
- May 17, 2007
- Threads
- 6
- Messages
- 14
I need to replace this on my cruiser, is this a design that oval tank is going to maintain or can I reference you when trying to purchase this.
Nice work! Most people don't think it's important to keep the evaporative emissions system, especially when they de-smog.
Anyway,for a good-looking fix for an out-of production part.
I have the Fed Spec smog equipment that came on the 8/78 FJ40. I have never failed emission testing (I’ve been close a number of years). I have 21 years worth of emission test records. This year was the first that the 40 was tested with the new vapor recovery tank. The vehicle passed the first idle test with readings so low that I did not have to re-test at 50mph. Initial idle test readings were; HC, 29ppm out of a limit of 250ppm and CO, 0.07% out of a limit of 2.00%. These are the lowest readings for HC and CO that have been measured at initial idle since I’ve owned my 40. The air filter, plugs and timing were not touched from last year’s tune-up for the 2007 emission testing. I did change from Castrol 20W-50 to Chevron Delo 400 LE (API CJ-4) 15W-40 which I also run in my turbo diesel. I did rebuild the carb a number of years ago, except for the primary jets which are larger, everything else is to factory specs for gaps and angles.
I have a Fed-spec '78 w/ a 9/77 build date. I thought my vapor recovery unit had 4 lines into it vs. your 3?
I'll have to take a look...
Thanks for posting this! Good stuff!
I dig it! Better than the original plastic stuff, and fits like factory! You'd never know it was there without disassembling stuff. Do you have anything indicating the construction of the thing? It looks simple enough to just make from scratch.
the tank is still pressurized when I stop to fill up. Is this normal?
Are you sure it's positive pressure, and not vacuum? If you have a check valve and a vacuum draw it would have negative pressure, which would be correct.
i built my own recovery tank out of 2 inch plastic pipe. the lines from my 28 gallon tank all to the bottom of my 5 inch long pipe with caps on both ends. the input is from the tank and the top is an output from the tube to the charcoal canister. I don't have a canister so I piped it into the air breather. works fine and no gas smell in the cab. no pressure on the tank either. Note that some model have to have a vented cap that is how they were disgned, but of course that fails emission check. so buy a vented cap and keep your non vented and when you go to pass emissions put on the non vented cap. you can pick up a vented cap from Napa part # 703-1034
Think that will pass a visual smog test?here is a picture of my setup. I no longer get the pressure build up and since I routed the output into the breather I don't smell fuel as it gets sucked into the engine. it does however still smell when it sits in the garage and it is hot. so I crimp the hose so it is in a closed loop.
See attached picture. I mounted it above the tank on the roll cage.
