- Joined
- Jul 22, 2012
- Threads
- 639
- Messages
- 17,564
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
@cruisermatt can you point me in a direction for the fuel fittings?
That’s a vague question, which ones?
Pull that plate with the original fuel lines through it out and see what they look like inside the tank. They most likely go all the way towards the center of the tank. Check inside the tank and see if there’s an existing pan/tray around where the those lines pickup from.
You should be able to use that same pickup with an electric pump. Buy the universal in tank electric fuel pump unit for about $19 on Amazon. trim a few inches off of the metal pickup line that you have and attach the new electric fuel pump unit to that so that could pick up from the new pump is in approximately the same position. Should work fine if you have enough clearance to fish it back in side the baffles where it came from. you may be able to trim a notch in the top of the baffles with some tin snips to get the clearance to fish the pump back in. Of course you will have to drill that access cap for the wires to the pump and seal it back up with some type of sealant.Yes, appears to be baffles that this pick up sits inside near the middle.
Drill hole in Access cap. Run wires through with a tight rubber grommet installed in the hole to prevent wire abrasion/short. Clean and degrease metal and Seal with a good fuel resistant sealant on the inside and outside encapsulating the rubber grommet and point where it goes through. If it were me I'd probably use JB weld paste followed by putty.I ordered the toyota fuel pump kit that @cruisermatt has posted up earlier, so when that comes in, I will see if I can get it attached to that oem tube and fit into the tank. Been trying to find what to use for the wiring, and found this on ebay..... Anyone else have a suggestion?
Wire Bulkhead - 2 hole - Fuel Cell | eBay
Find great deals for Wire Bulkhead - 2 hole - Fuel Cell. Shop with confidence on eBay!www.ebay.com
www.psiconversion.com
I'm of no help... but have been following along. Next time I visit the folks in Topeka I'm popping in to see all this stuff in person...
ok... talked to PSI Conversions. Quick plug, they are awesome help to work with. .. Dominic was very helpful.
Word is that there is not a harness for a gen3 motor and a gen4 6l80 transmission.
So my option is to find a 4l80 transmission or go deeper in the rabbit hole and find a gen4 motor and transmission. If I do that, I will buy an entire car and do a swap.
Any advice on this rabbit ho.e?
