I have no codes after swapping the fusible link.
@BILT4ME You screwed me bud.
I thought I was well outside of your envelope, but not the case. You were right, I was wrong.
It is relevant insofar as you guys should all convert to turbodiesels.Signature suggests that poster does indeed have HDJ80, so it doesn't seem relevant in a discussion of fzj80 mpg woes.
Time to replace all the rubber lines especially gas lines.I had been fretting about a fuel mileage issue in our '94 as I was getting it ready for my daughter to take on a 700 mile trip. I had the hood up and engine running looking for a noise on start-up (loose belt eventually). Anyway much to my surprise a fine spray of fuel was spraying out of the fuel return line towards the block......
Yes, I need to go about this systematically. We have done the major coolant lines including the PHH (not rear heater). I got both return lines in the fuel system now I need to look at a diagram of the rest of the system and the vacuum lines near the firewall. A mechanic did look it over pretty well before the trip.Time to replace all the rubber lines especially gas lines.
At this point there 30 years old.
Please do this before sending your daughter off on a long trip.
It looks like a very clean rig !Yes, I need to go about this systematically. We have done the major coolant lines including the PHH (not rear heater). I got both return lines in the fuel system now I need to look at a diagram of the rest of the system and the vacuum lines near the firewall. A mechanic did look it over pretty well before the trip.
The car became a modest celebrity last week as the trip was about documenting her and a friend's rock climbing for their sponsor. The car became the setting for much of the non-climbing dialog and the video crew fell in love with it.
End of a day of climbing, The Coliseum, Summersville Lake WV.
Yes, its basic role was to get from DC to a weekend spot in WV that routinely required chains in winter. Other than that it was garaged. I still have the original factory carpet mats stored away. They have less than a month's use.It looks like a very clean rig !
Wow, agreed on a clean rig. If you replace the front seat leathers and want to sell the originals let me know. They look in better shape than mine! I am in MD too.Yes, its basic role was to get from DC to a weekend spot in WV that routinely required chains in winter. Other than that it was garaged. I still have the original factory carpet mats stored away. They have less than a month's use.
Looking to get the 1st & 2nd row leather & foam replaced with either LCH or Katzkin in the next few months.
Yes, a few possibilities actually. It would be very helpful if you noted the Vf1 and Vf2 voltages. It's a starting point as to what the controller is trying to do. You will need good O2 sensors for those readings to mean anything though.Rig has been at the shop for 2 weeks now.
Got a call yesterday about my O2 sensors.
Owner said the rig is running rough & very rich. Which it is.
Cold start, it’ll run rough til it warms up. Usually evens out at about 100-120 degrees.
Running rich makes sense as I’m getting horrible gas milage.
Shop said that’s why it’s throwing both O2 codes, but it’s not necessarily because of the O2 sensors that were recently replaced.
They said by next week they should have an answer.
Any theory’s as to why it may be running this way?
This likely wont help with mpgs but what do you mean by "factory?" The OEM tires were a P-Metric tire and if your tires are currently an LT you would need to look at load inflation tables to have the correct PSI.Tire pressure is set to factory, aired at Costco with their air mixture.
