Under 8 MPG
I do have the OEM gears still.
So the calibrator should assist me, correct?
Re-gear has always been in the plans, but $$$. Not going to happen within the next year.
I live in southern CA. Sea level, mostly flat, don’t intend to go with bigger tires, & no towing.
Can you explain the math involved regarding the tire size discrepancy?
The calibrator will do nothing about the torque converter lock up or lack thereof. You either need to run stock tires or regear. You also have the option of regearing the t-case vs. the diffs. Georg and Valley Hybrids can help you with that. I ran 4.88's and 35's for years. The engine revs higher on the freeway but the tradeoff was worth it for me. I pulls the hills in SoCal much better being undergeared. However, if you lived in say Utah and did 80+, well that screaming engine gets annoying so 4.56's might be favored. It's really up to you to decide the balance of tradeoff's.
As for the math. It has to do with the circumference of the tire as defined by the distance from the axle to the ground. A larger diameter goes farther with each turn of the wheel. Your speedo is simply measuring turns of the driveshaft which is calibrated to the stock gear ratio and tire size. When you increase the tire diameter that calibration is now inaccurate as you are going farther with each turn of the wheel than with stock tires. The actual equation is S=r * theta. S is the arclength, r is the radius (distance from axle center line to ground) and theta is the angle of rotation in radians. However, if you were to find the ratio between larger and smaller tires, theta cancels and you are left with the radius of the new tire over the radius of the old smaller tire so the difference is simply new radius / old radius.
You can also just look it as a difference of circumferences. which is 2*pi*r or pi*d (diameter). In this case pi cancels and you are left with the ratio of diameters. This will give you the same answer as above but let you work with diameter instead of radius. I believe the truck has 31" tires originally. 35/31 = 1.129. If you multiple 8MPG * 1.129 you get 9MPG. That's because you went more than 8 miles / gallon, you went (8* 1.129) miles / gallon or 9 miles / gallon.
Frank
UPDATE:
A few things were off & now corrected.
Wiring to the MAF was bad. The connector was repaired & working properly.
The MAF was dirty, now clean.
I had a collapsed vacuum hose. Unsure which exactly now.
All these corrections fixed the stutter, stalling, & bad idle.
This weekend I FINALLY got the speed sensor replaced.
The problem is NOT the sensor unfortunately.
I’ve got a buddy with a wrecked LC I can pull the gauge cluster from. He’s currently out of town & wont return for about a week/ week & a half.
Once I get that in hand, I can proceed forward.
At least with the gauge cluster out, I can replace the “D” bulb & pull the ABS bulb.
UPDATE:
Interesting — thanks for sharing! How did you discover the collapsed vacuum hose?
So what's the mpg now?
Took it to a shop to diagnose.
They discovered the collapsed hose & bad wiring to the MAF.
I’d love to know the current milage. But a non-functioning speedo also means a non-functioning odometer. They are tied together.
  • Like
Reactions: CJK
You could use GPS on your phone if you just wanted to do a run and see if it made an appreciable difference.
Frank
Interesting issue occurred today.
Speedo/odometer are still only intermingling working after replacing speed sensor 83101-20040.
Figured the gauge HAD to be the culprit. Still getting my hands on a new-to-me cluster, but have located one.
Yesterday:
The P0500 engine light came on.
Can a faulty gauge cause this?!
Or is another sensor bad? I did purchase two speed sensors 89411-50010, but never installed them.
Are these two sensors the ABS speed sensors at the wheels? Could they cause this?
I also head there is another transmission sensor that could be the culprit. Are these two other sensors go to the trans?
I don’t want to just throwing parts at this thing…
