- Thread starter
- #21
The ol' set it and forget it relay rod. GFD
Those brake calipers look to be the GM metric type, wonder what bracket was used...
Yes.
I was hoping so when I first saw it but the other side looks like a factory weld and it was hit hard on this side early on based on what I've seen. I need to clean up the other side and look a little better, but I only bitched because it appeared to only be one side. Lots of weird s*** on this thing. It was either a Monday build after golden week or was hammered to s*** and put back together half decent early on in its life for the tech available to do so.That knuckle weld may be from a cut & turn, no?
I assumed JTO. This truck appears to have longer spindles than the 73, which is strange to meThose brake calipers look to be the GM metric type, wonder what bracket was used...
Nailed it, found the evidence of the other side when looking from underneath . Wish I knew who started this thing, they actually knew what they were doing. I've seen people charge money for worse.Yes.
So, coarse-spline birfs then?I assumed JTO. This truck appears to have longer spindles than the 73, which is strange to me
I have one, and would use it if I felt it was that simple. It's not, as the layers aren't even and there's up to six in some spots (black, brown and tan spray paint on top of grey then white single stage aftermarket paint on top of red oxide primer) coupled with the panels aren't perfectly straight. Some spots have no red oxide or base white and just have the aftermarket grey single stage hidden by one layer of spray paint that wipes off with a little thinner and shop towel. Others have all the layers and are VERY thick (think fingernail thickness, no joke) and takes considerable attention. Last picture in post 35 is a good reference for this as it was all knocked down with a block and 600 grit wet. It went quick enough. I'm just trying not to burn through more than I need to because it's a quick tipping point. I personally get more visibility manually, as well as can feel where thick spots are or aren't.Looking good! Just keep thinking about where you started at! This looks rad.
Have you considered a simple polisher from HF and some good compound? I went over my whole 55 with a hard cutting compound and then a medium polish in just over a day. I like the electric machine as it allows a lot of control if you want to really hit an area or if it just needs a light touch because you are about to punch through the last bit of paint.
Just a suggestion. But for $100 you could be flying if you don' already have a polisher. You'll save days at this rate.
