Build Troopie build
Status
Not open for further replies.
I'ma gunna steel that rack.....idea.
turned out okay ...
factory switches fit the openings.
to be powder coated black.
the front and rear consoles completed and installed.
the panels are also removable ...
lots of room to enter the rear without having to go outside the vehicle.
test fitting the location for the wabasto and the isolator.
brackets built
ready for PC black.
quick disconnect for front console ... the extra wires are for the owner to use if desired.
wired into the aux fuse panel.
self adhesive reuseable zip ties for the A pillar.
one of the joys i have, being able to build vehicles that i would never be able to afford to do for myself.
all i can hope for is that you are as happy when you get the vehicle as you are with the pics.
i have strived diligently to give attention to detail in every item i constructed. when you take a close look at the build in person, i believe you will see this for yourself.
as for hurting, giving birth is a painful experience ... so i am told ... you are giving birth to a very big baby.
Fricken sweet! That sliding cargo barrier is a genius idea. :D
Good choice in audio too. The head unit with USB is a great way to go. No more skipping CD's!
61MK+ your going to enjoy this rig. You realise we are going to want semi-regular updates once you take posession and lots of pictures of it out in the wild! :D
Status
