TRD PRO Wheels on 40
It's all good.
I love me some stock steelies on a '40.
I'm putting Vintiques Smoothies on my '40.
But them alloys look nice, too, for sure.
I have forged rims on my 200.
Variety is the spice of life!
They will fit just fine. The front tires will be too far in to turn stop to stop. The tires will hit your springs. If you adjust your stops out to keep the tires from rubbing, your turn radius will suck. I did it with my FJCruiser rims on my 40. Spacers are the only option to use your rims on your 40. The tires should fit the rims just fine.
Great, will be interesting to see fit and function. I've redone the entire suspension (OME 2.5") and went to discs at all four corners.
So won't have wheel fitment issues, but probably will get some rubbing at full lock without spacers. I'm fine with spacers because I want to be at fenders edge if not a little proud. I also like the idea of ample track.
It's all good.
I own an LC200 also. I put 20" Method Racing "basket" on mine.
They work fine for what I do with that truck. Really just move the fam and two dogs around with a couple remote cabin trips to Blowing Rock NC each year.
What brand and model forged wheels are you using on your's?
What part of fl are you in
If your looking for a way to order the trd or trail team wheels that normally go on an fj cruiser you can find one forsale that has the vin listed in the add and use that vin. I remember people doing that on the fjc forum to be able to order the special edition wheels and trail teams trim if they got a dealer that didn't want to sell without vin.
The Toyota magazine that comes out put some of the trail teams 16 wheels on a cruiser a few years back. They put on wheel spacers I believe so they would clear.
So, strong, light wheels would be a bad thing on the trail? I wheel couple of times a week, with a diverse group, trying to recall when I last saw a rig on the trail with steel wheels? We have steel wheels on our trailers, so there is that.
All of the FJ40s that I'm around that have steel wheels, are for the look, stock steelies are the fashion rage, rarely if ever wheel, maybe dirt roads, if that. The ones that wheel often, all have alloys. Maybe it's a local thing?
It must be local. Here on the East Coast we see some of both. The beach cruiser guys will run them because they rarely leave the sand or BLVD. They usually have plenty of chrome and lots of bling on them as well. Lights everywhere snorkels 14 inch wide rims with 12.5 tires you know the drill. most guys who run in the mountains and rock crawl will run steel because they are gonna get beat on the rocks. Steel beadlocks are preferred though as alloy beadlocks are very expensive and easily damaged.
I'm in SoFLA. Good on wheels, 5ea Taco TRD PRO wheels in hand. My TRD Corprate connection confirmed the VIN guidance to resellers, to ensure availability to actual Taco/4R Pro owners. Suspect it will be lifted once supply increases.
Thanks for the advice. The big muscle movement for me will be taking top off, installing family cage for safety, and doing a full length custom canvas top (no walls/windows though), likely in light gray.
Closest wheeling, that has elevation, is Ocala National forest and even that is more hills than anything else. Mine still has the original F engine with 93k miles on it. May trailer it to Blowing rock area at some point. Puller: 2009 LC200.
You're generalize here, but I don't entirely disagree with you.
You think FJ40s get blingy, try Jeep owners! I see Rubicons daily that have $20-30k of mods on them and we're in flat FL. Or check out Asian rigs!!!
My pics are in the thread. I try to look at function and reliability over look. As someone else mentioned, Toyota wheels, especially TRD, go through a ton of testing. Unless you are trying to address unique use profile like mudding or rockcrawling, an OEM wheel will meet 95% of the requirement and can be aired down to ~15 psi safely for that stuff.
Steel over Alloy any day for me. Just my personal opinion from working in the tire & wheel assembly business though. I find TRD Pro wheels (and many aftermarket alloy wheels as well) beautiful but a lot of "fluff".
The bead lock rings that some of them come with are not even functional and are a PITA to deal with during assembly/disassembly process if you don't want to scratch them.
I'm going a somewhat different route to remove some of the chrome bling on my 75. I've ordered up the FN FX Pro wheels in black which are essentially the same as the TRD Pro wheels except they come in 17 x 8 instead of 17 x 7. They did mention the centers will have to be milled to 108 for the FJ40 front axle hub. The wheel comes standard tapered from 101 to 106. Probably 30 to 45 days out and I'll post up pics.
What is that "very good reason?" And why do "most people who actually use their 40 for off road shy away from alloy rims entirely?"
Strength, durability and correct offset. The OEM steeliness are damn near perfect.................
Ok- Changing this up a tad.
Debate for me is over. I own x5 TRD Pro Wheels for my 74' FJ40.
What I would like is some opinion on 285/70R-17 vs. 275/70R-17. Theoretically there is .5 inch difference in both width and diameter between the two. The 275s are cheaper marginally. I am NOT basing my decision on wheel width. Either if fine from my Trophy Truck contacts...
Really just a question of weight and rolling/steering resistance between the two sizes. Suspect it's insignificant between the two, but would appreciate input.
Thanks to all!
LR
The offset may require spacers. Some people don't like to use spacers, but there are plenty of people who do use them.
x4 Spidertrax Spacers (Model# WHS005) sitting in garage. If I had time, I'd test mount with just wheels, but not much point in that. Product is a work of art!!!
Really satisfied with quality. Hope satisfied with tire fitment as much!!!
Just how a plain steel wheel wouldn't look right on a 2017 pickup, nor will those look right on a forty year old toyota.
But to each his own.
Poser- In a word, yes. The Spidertrax 2" spacers are hub centric front. Rear is a little trickier. The spacer of course bolts to the disc brake rotor. It does align due to the Spidertrax design both on the spacer and acorn style beveled nuts used. The final step of wheel is good to go with the modern Toyota wheel nuts that self align the wheel to the spacer studs and have a floating washer as part of the assembly. Tough to tell by pics but front tires are a little proud of the front fenders and the rears are perfectly aligned with the Bushwacker flares.
Do you wheel spacers make the hub-centric wheel work on the non-hub-centric 40 series front and rear axles?
The hub-centric thing is a bit fiddly, but not a big deal. Install the wheel with acorn nuts on every other lug, snug them to center the wheel, put washer nuts on the other studs, torque to spec, remove the acorns and replace with washer type, done.
