Yes it is.
@bdyer12 and I were talking last night and he made a good comment. "This mod is better than any motor swap combo, it just makes the car modern"
J
exactly why I’m doing it with my new 6.2/6L80e
Yes it is.
J
Yes it is.
J
I wanna do this with an 80 rear and my 62 series front80 axle/coils swapped over today. @matthews940 and AJ have both helped out tremendously on this little project with me being sick the last 7-8 days. These are my custom TourFlex 2" tapered wire lift coils. We designed it based off a 2" lift. So if you want a 1" lift ... Order a 1" lift coil... Want a 3" lift... order a 3" lift coil. Perfect 1" rake on this rig. Should dial in around 4 degrees of caster and ride amazing with the custom tapered TourFlex coils
We tested 3 coil sets today and we are at a perfect inch to inch ratio. Stock coils-- NO LIFT , 2" lift coils-- 2" lift, 3" lift coils-- 3" lift.
Kit is pictured and what will come with all TT front coil packages (TD solid adj. panhard additional)
Front complete bracket kit will be $935.00 PLUS SHIPPING- (taxes apply if in CA)
2- shock/coil buckets
1- PS support bar with bracket
1- Panhard bracket
2- Rear Radius arm brackets
2- "Stock" transmission adapter brackets
All brackets are frame indexed and direction oriented for ease of fitup and installation.
Jason
Wow, just wow. I need on this list. Before I go search for 80 series axles... did you mention your working on a coil spring conversion for the stock 60 axles?
I don’t see any advantage in rear you can get an 80 FF w/ disc brakes.What would be the main reason to keep a 60 axle versus going to an 80 axle? Width? The part-time hubs? being able to retain a stock wheel or 15 inch wheel? Or something else?
Only advantage I can see for front IIRC, the 80 diff is a different size and may not be as strong (correct me if wrong). You can get part time hubs like TT is doing for me, just have to cut birf
I'm thinking better brakes would be nice ,disc in the rear is definitely nice not sure how much better the 80 front brakes are than the 60s, does this open up any better brake upgrade options vs the 60 and the tundra upgrade?
Hawaii, Kansas and Alaska and International do NOT APPLY.
I'll be working on a 60 axle coil conversion in the next couple of months. We'll probably convert @Matthews940 to coils and keep the 60 axles.... HA!
Jason
I’m definitely your target audience with this. I have no problem with the 60 brakes or axles... I just want coil springs. Like really really want them. When time opens up I want on your list JThe only advantage is cost outlined above (but with drums) and for those wanting a stock width... They get the benefit of the ride quality.
J
What did Kansas do?!
Damn. And I thought CA was bad
