- Joined
- Jun 21, 2011
- Threads
- 238
- Messages
- 22,263
- Location
- Redding, California
- Website
- trail-tailor.com
- Thread starter
- #1,021
How soon will the 100 series antenna mounts be available?
Available now, just need to get them up on the website.
J
Ordered, thanks!Available now, just need to get them up on the website.
J
Hey man, I've been bugging you for one of these since December 2016 (check your emails)!
UCAs - 100 Series
Toyota Land Cruiser 100 Series 3 Degree fixed caster correction Currie machined joints - 2.5" OD full flex, no bind joints - rebuildable and greasable 4130 CrMo wall tube arms 4130 CrMo ball joint cups Sealed maintenance free tapered ball joints with 4140 CrMo ball stems and SAE 1045 forged...trail-tailor.com
A couple of more sets are available on the website.
It was UCA Monday... HA
View attachment 2006173View attachment 2006174
Why are some of your UCA have t this brake line mounting bracket? The one I received today didn't have it.
Antenna Mounts
Toyota Land Cruiser Antenna Mounts 60 Series 80 Series 100 Series Convert the stock location to a dual CB and AM/FM antenna This mount will need a CB splitter and other components to complete the installtrail-tailor.com
J
Jason, is a stronger than oem gas tank skid plate still something you might entertain in the future for 100s?
@TRAIL TAILOR Jason do you have any ideal alignment specs using your UCA's? Just wondering given my mechanic just sort of winged it. It rides okay, but feels like it's got some loose high steer movement. I'm running your lift kit, with the dual rate springs. Would love to dial it in better once I put my new wheels and tires on next month. Any info would be great!
Usually these guys are pretty good and are known around here as the go-to guys for off-road. I caught them at the end of the day on a Friday and sort of feel like they got it so it worked, and sent me out the door so they could go home. Definitely not their usual service. I'll give them a chance to correct it, before I throw in the towel on them. I'll double check my measurements and try to see where it lands. Thanks Jason for the quick response!I've seen quite a large alignment range (3.5 to .8) just depends on the shop and how high you are cranked. Most are in the 20.5-21.5" range and getting around 2.0 a majority of the time.
Take it to an alignment shop that knows what they are doing. I've found and heard most are far from reputable and experience is lacking.
Sounds like your mechanic installed and turned some bolts and eye balled it... Not a good idea to run it for long and honestly I wouldn't.
So is your goal here to rip on someone’s livelihood? If you have a question on this it would seem that a private message or email would be more appropriate than the thread where he posts his hard work and support of our niche community.Why aren't the supports connecting the round outer tube with the rectangular inner tube, plates and not tubing? Seems like a great place to snag... round tubing there would be the ticket.
