I don't really have "plans". I just made a 3D CAD file in Autodesk to give me an idea of what I would be doing. It's just a visual reference to guide me as I am bending and cutting metal. Your more then welcome to print out my pics and take them to any fabricator to have it made. I'm also open to sending you any pics your fabricator needs or files he could use.You willing to share the plans? I have been wanting to get some plans to a fabricator and I really like the looks of this. If not, no worries.
my taste is different from yours, I like the straight up and down aesthetically, out of curiosity is there an advantage with the angle?
really interested in seeing how this will eventually turn out, props.
I have two reasons why I want a stinger. One is to make sure a deer doesn't smash my front end. I live up in the mountains and see deer regularly. I also want a stinger so I have something to attach the bars that go around the headlights. I have busted a few headlights on trees in the past and like having a bar out in front of them to push branches out of the way.It's funny how many "off readers" run stinger bars, and have no idea of their intended purpose. A TRUE stinger is set up to keep a vehicle from doing a face plant or endowing. 99% of so called stingers are for show, real stingers are fabbed right into the chassis bars.
It mounts with 4 screws on each side (provided by Trail Gear). It uses the same holes that the OEM tow hooks use on bottom and the two up on top. 8 big bolts should be sufficient.That actually looks really good. Great job!
By the way, where does the winch-mount mount to on the body?
No sand needed. I'm bending 1.5" tubing. I have 1.75" shims that go between the tubing and roller wheels. It allows the tube to roll along the wheels without getting creased while you bend the pipe. If you can allow the wheels to roll along the tube freely then it's way less prone to kinking at the bend. Here's a shot of the shims. Works great. Also this is a "pipe" bender and not tube bender and there is a difference. Pipe is measured by ID and tube by OD. The 1.5" pipe mold is way too big for 1.5" tubing. I had to use the 1" pipe mold and then had to take the grinder and grind down the sides of the mold until my 1.5" tubing seated down into it super tight. A 1.25" mold would be perfect but my bender didn't come with one that size. If the mold is too big it's guaranteed to allow movement and kinking. There can be zero movement or gap of any kind. With the shims and the 1" cast ground down to the correct size (1.25") it works perfect. It's a bit extra work but if you have time, it's a big cost saver compared to other pipe benders.Are you filling the tubes with sand prior to doing the bends? The biggest drawback to the HF bender is that it crushes the pipe, unless you fill them with sand. Your bends look nice.
Cool. I have one of these benders so I may have to give this a try and see what I can do. Thanks.No sand needed. I'm bending 1.5" tubing. I have 1.75" shims that go between the tubing and roller wheels. It allows the tube to roll along the wheels without getting creased while you bend the pipe. If you can allow the wheels to roll along the tube freely then it's way less prone to kinking at the bend. Here's a shot of the shims. Works great. Also this is a "pipe" bender and not tube bender and there is a difference. Pipe is measured by ID and tube by OD. The 1.5" pipe mold is way too big for 1.5" tubing. I had to use the 1" pipe mold and then had to take the grinder and grind down the sides of the mold until my 1.5" tubing seated down into it super tight. A 1.25" mold would be perfect but my bender didn't come with one that size. If the mold is too big it's guaranteed to allow movement and kinking. There can be zero movement or gap of any kind. With the shims and the 1" cast ground down to the correct size (1.25") it works perfect. It's a bit extra work but if you have time, it's a big cost saver compared to other pipe benders.
If you want to bend 1.75" tubing then use 2" tube shims and the provided 1.5" mold that comes with the bender.Cool. I have one of these benders so I may have to give this a try and see what I can do. Thanks.
