TP Daily use
San Juan Puerto Rico
Website
www.facebook.com
What tire pressure you run on 33.10.5/15 on an OEM wheel, and 315.70/16 OEM wheel for daily use?
The wheel size should not impact tire pressure, the tire itself should dictate the pressure and tire width should fall within the tire manufacturer's specification. Your "sizes" are not properly stated so its difficult to interrupt what your concern is beyond the differences between a 15" versus 16" wheel size.
You are asking a question similar to, "how long is a piece of string?"
It depends on the load rating of the tires, along with the weight of the vehicle, and your ride comfort tolerance.
On pavement: anywhere between 32-50 but usually closer to 38 to 40. Depends on tire rating. I have BFG KO2.
What they are at the moment is anyone's guess. Need to check.
It's not that technical really.
Anyone else?
I run BFG KO2 on two different vehicles one lifted, the other is totally factory. The non lifted is used daily, and after 3 years, the tires are worn like "scalloped". That never happened with the prior set of tires which were KM2s.
I not certain what you mean by "scalloped" but that could be caused by wheel balance, alignment or a problem with wheel bearings. A tire pressure issue is normally related to uneven wear from center to edges but around the tire diameter wear is even. Scalloped to me indicates uneven wear around the diameter.
Edit: I should also add to the list of possible problems causing uneven wear would be worn shock absorbers.
Shocks need to be replaced.
If shocks are new and you still are not getting proper wear then you need to go deeper with tie rod ends, bushings, alignment, bent axle etc. in addition to what I listed in my posts above.
I run 35 psi cold and will be rotating wheels and tires every 5K miles religously.
I dunno, I have found the tire size in inches a very simple practical guide: 33s get 33psi, 35s get 35psi, hubby's Blazer's 37s get 37psi, and so it goes . . . :meh:
on longer highway drives, I usually put up to 5psi more - so the 315s on our 80s get 35 when airing up after a trail ride, and had just about 38-40 when we drove them from Phoenix to Yellowstone this summer
TP? About 5-10 squares per day. Sometimes more. :flipoff2:
(285/75/16 Duratracs on a heavy Cruiser, about 36psi)
Everything that is front axle related is fairly new. The only thing that I have not checked is alignment. I'll do that asap
M/T and A/T, or any tire with large blocky treads will usually “cup” or “scallop” if not rotated often enough. Not only front to back but run the other way (the other side of the vehicle). I have seen a bad shock make this same thing happen fast on only one wheel. But every set of ko2s I have had did the same if I slacked on rotation.
How does it feel on a smooth road at highway speeds? Smooth as glass? If not I would rotate and have the tires rebalanced. Any vibration caused by tires being out of balance can lead to cupping on the outside of the tread.
If you wish to get the maximum tread life out of your EXPENSIVE off road tires, you need to not only follow
@lumbee1 advice in regards to rotation, but you'll also want to include balancing to this schedule. Because as the tread wears, the balance will be effected too.
285-75/16 Duratracs here. I run 32 most of the time around town and for comfort.
I have been running 42 lately for better gas mileage, as I have spent MANY miles on highway. The intent is to wear more in the center.
My truck is a DD.
I have 72000 miles on my Duratracs. They are getting worn finally and have been cupped for a long time because I did not rotate often enough in their early life cycle. Definitely need to rotate every 8000 miles or less.
