- Thread starter
- #581
With each step it gets closer!
Doug, do you see any reason I couldn't put the power steering reservoir on the drivers side fender well?
Looking Good Ryan.
Thanks Doug. I'll check next week on the hood closure. Going to panel bond the inner hood back to the outer portion of the hood first, then install.
Sounds like the relay/solenoid is acting up, that could drain battery. What else is hooked up?
I would also ground engine to frame and battery, plus several body grounds.
Do you only have the frame grounded?
Factory Isuzu has a ground from battery to frame, body, engine and starter. You can not have too many grounds. Isuzu has 2 batteries stock, which I also have.
Are you using a Ford starter relay between the stock Toyota key signal wire? The Isuzu needs more amps than the 2F, which will burn up the key switch contacts.
I bonded my hood many years ago with a 3M body sealer. It made the hood sound really solid, and no issues. I filled most of the voids between the hood skin and inner structure.
