650°F .. ? naaaa dude .. you are way off fuel .. !
Put more diesel on it . !
otherwise the 10psi of boost is a kick in the pants! it pulls hard, and sounds great, absolutely LOVE this machine!
Well I followed advice on a site I saw, Installing A Turbo On A 1989 2.8 Liter 3L Hilux Diesel Engine - 4wheeling Canada - Off Road Junkes!
And yes the 650EGT's were degrees F I have always read that the more diesel you add, the higher the EGT?
Told ya. They get better the longer you drive it, as you adjust to the torque and power curves of the turbo diesel.
The blue smoke sure sounds like it could be a turbo oil seal. Does it make a big belch of blue smoke after idling for a long time?
Those EGTs sound low to me too, but on the trail you don't have the ability to get the engine REALLY hot. If you were to take it out and drive up a long steep hill (a few miles) I bet you'd be more in the 900+ degree range. Yes, adding more fuel increases EGTs.
You made quick work of that project, BTW. Good job!
Dan
If that reading is in F, then I wouldn't trust it at all.
Got photos of the probe location and how long it is?
Those post turbo readings are not that accuracy .. but 900°F post turo seems to be ( IMOP ) a reasonable conservative number ..
It's cold where you are .. how much . ?
When was the last time did you check the IP and injectors . ?
When we did the trail run, it was in the 70's F, I am not really sure how to check the pump/injectors?
I have tried just venting the pcv, and it still does it, I did a compression test, the numbers looked great, plus they were within 20 psi of each cylinder, so I am thinking like you either valve guide, or ring, but I would think that with a ring, wouldnt it do it all the time?, and my experience with valve guides seals is that it usually only blows blue at startup, not intermittenly after it gets warm?
I have tried "Rislone" treatment in the past with ticking lifters, and it worked great for me, so I am trying this in conjunction with some lucas injector cleaner, and will take it out for a run this weekend, and report back!
Perhaps it is a stuck ring.
