Tool loaner thread… not for mooches.
Wow, that thing is a monster! Should work fine for my little 2.0L TDI. I’ve been a little busy over the past week, would it work to catch up this weekend and figure out a time that works to come pick it up? Shouldn’t need it for more than a month or two.
It mostly sits, if it'll work for you, just let me know when you'll be thru
I’m planning on heading to Paul’s if I cannhelp
Move some stuff around
Is this still in the planning stage or has it already taken place? Weighing my options right now and considering a trip to Helena this weekend if nothing else works out.
I'm looking for a bushing puller set or home made version.
I'm gonna do a Lower Control Arm replacement on my 100 series. The rear bushing is pressed into the cross member. To remove, I guess there is some all-thread and a couple of large sockets/pipe required. Anybody done this and have the homemade tool?
Trying to picture this. I’ve replaced the lower control arms that come with bushings installed several years back and am not recalling a bushing in the crossmember. Nevertheless, you can borrow the tool if you need it.
I ended up tracking one down thanks guys. Also just ordered one for myself now FYI no one in town will sell you or loan you one at Riley’s or CR(n)apa or vatozone
I have one, its the thin walled version @ttFJC
Needs to burrow a 54mm hub socket
I don’t think I have one
I gave mine away to another member at a meeting at Map a month or two ago. Pass along before I pass on.
Does anyone have the SST combo 09213-54015 and 09330-00021 (or equivalent), crankshaft pulley counter hold tool for a variety of 4-cyl and V6 Toyota engines? Specifically looking for one that works on a 3.0L 1MZ-FE.
Looking for a riv nut tool to install 4mm x .70 pitch if anyone has one. Thanks in advance!
Thanks! I think I located one in the morning but if it doesn't work out I'd love to borrow tomorrow if possible.
Sounds good. If that falls through give me a shout, I’ll be available any time after about 5pm tomorrow.
