My 2002 with 190,xxx miles started running rough the other day when I pulled into the driveway after a short trip. I ordered new timing belt, water pump, etc. and took everything apart. Turns out taking it apart was the easy portion.
I marked the old belt before removal and transferred marks to the new belt (even though the new factory belt had marks on it already). The marks lined up from the old belt to the new belt. The problem was, when I got back to the car to test fit the new belt I was a solid notch off between the cams. I shifted the passenger cam a hair to get it back to where it was when I took the belt off (I took pictures and it seems to have moved around one notch to the left after I removed the timing belt the first time). After I got the belt to fit the cam pulleys I slipped it over the crank - now the belt is a solid notch off at the crank.
Here's where the fun really starts - I tried to force the new belt onto the right grooves at the crank and somehow managed to slip and rotate the drivers' side cam around 35 degrees.
I'm nearly at wits end on project timing belt - is there a simple fix for this or am I biting off more than I can chew?
Any help is greatly appreciated - any snide comments are welcome, but I can assure you the self loathing is doing the job just fine.
