Time for a new winch
IL
I burnt up my winch today on the trails. It's time for a new one. It was a badlands 12000 lb winch. What do you guys recommend? I was leaning towards a warn but was not sure if a 9000 lb winch would be enough. I have a AOE front bumper. It would be nice to have a winch that actually fits. I had to mess with my grill to get the badlands 12000 lb winch to fit.
I have a T-Max 10000 lb winch that came with my truck. I've had to use it a few times and it's worked flawlessly. Also, I like that the solenoids are in an external box so of one goes bad I don't have to take the whole thing apart.
Just out of curiosity what did you do to burn up the badlands? Anything crazy or just a standard pull?
Why not another cheap Badlands K? Maybe buy two and carry a spare.
12k winch all day. I have a warn Zeon 12 and even it has bogged down at times.
I don't believe in buying cheap recovery equipment, it's a personal opinion (which many share) yet others will sing the songs of budget winches all day long.
What I can say is that if that was a warn M12 or equivalent this post probably wouldn't have been made.
Out of curiosity, and not to hijack the thread, what bumper are you using with the Zeon 12.
Just regular use.
The guy at 4x4 Labs recommended a winch when we spoke on the phone. Might be worth giving him a call. Some Canadian winch he reported (iirc) as overbuilt, bulletproof, and underpriced.
That seems kind of pointless, doesn't it? The last thing I want to do is carry an extra winch and have to swap a winch out because it fails.
So what is actually wrong with the dead winch? Dead motor? Bad relay? wiring problem? fractured spool? Repairs are out of the question?
I've said before & my track record between owning a well used, 2 owner M12K & a newer M8K - Warn winches seem to last.
I bought the 12K some 15 yrs ago now - rebuilt it with a new seal kit & took the time to grease the planetary gears. It still runs like a clock, and I wore a new wire rope smooth & round & replacd it with synth line 2.5 yrs ago now.
The M8K came used on the sold LX450, had just enough use when sold the synth rope was fraying despite it getting proper de-spool & washing quite often after outings.
I think it really comes down to how you set up your pulls - I always set up a single compound just to get further into the spool (aside from my winch on the quad, it's a winch that if I burn up a motor I'm out like $200) - so with the basic kit Warn has for free with a Warn purchase right now, you can do the same.
I'd be real interested to see if always setup as a compound pull, how long any of the "cheapie brand" winches might last - I prefer to stay with the Warns (mainly because you can buy rebuild kits, motors, solenoid packs, -parts supports if you choose to fix your broken / worn winch) -but really I bet if a guy didn't just do 1st wrap pulls alot of the lesser priced winches would last longer.
If you don't repair your winch - try doing compound pulls & see what it does for the lifespan of your winch. It would be interesting to hear, because really I don't see why a cheap winch you do your best to keep from straining shouldn't last say 40-50 pulls, and for some that's a decade.
It started to spoke and is now completely dead.
Yup, when you let all the spoke out there's no way it'll ever talk again......:)
