- Joined
- Jan 6, 2012
- Threads
- 341
- Messages
- 10,935
Both a 3fe and a 1fz are comparable in reliability if properly base lined.
3fe is not going to be reliable anymore due to its age.
I have personally know of at least (3) 1fz-fe with blown HGs (local), and this has been only 3 yrs of ownership.I respectfully disagree and have had the exact opposite experience. Prudence calls for baselining any vehicle of this age. That shouldn't confuse the fact that the 3FE's longevity and reliability is legend; it's literally one of the most reliable gasoline engines ever produced.
Im not saying the 3fe is unreliable, but it needs to be baselined to be reliable-and thats not a quick task. You have to replace every seal and gasket, all hoses, water pump, fuel pressure regulator, o2 sensor and cat, and reseal all electrical connections. And then its reliable again.I respectfully disagree and have had the exact opposite experience. Prudence calls for baselining any vehicle of this age. That shouldn't confuse the fact that the 3FE's longevity and reliability is legend; it's literally one of the most reliable gasoline engines ever produced.
Since we're mud-slinging nowI got my 91 5 years ago with 180,000 now it's at 260,000 at least 20,000 of those were offroad. Not a single issue on my 91 other than an alternator that went bad after a wreck and a leaky radiator. All my issues have been small maintenance issues. I am doubtful I would have been that lucky with the 1fze. Head gasket, pesky hose, exploding plastic radiators. I sold my 88 fj62 with 412,000 on the odometer in 2007. It had never had work done on the engine.
...I'm not offended and I hope you're not either. I've always foundI am not sure why you feel the need to resort to foul language emoticons to express yourself....... I am sorry if I offended you with my opinion and experience with my rig. everyone is free to have their own opinion. I would not consider stating my experience with my rig as " mud slinging". Again I am sorry if I offended you.
to be a friendly icon The 1fz is a iron block with a LONG aluminum head. To the best of my limited knowledge the 3fe is iron block and iron head. When over heated the 1fz will be more prone to warming a head and then blowing a HG. Aluminum and iron expand at different rates when heated. I dont consider this being "less reliable". To me that is like saying "when motor XYZ is run without oil...". Dont run your motor with out oil. DONT OVER HEAT YOUR MOTOR! Even a 3fe will not be happy if you over heat it. That is simple auto stuff 101.93-94 had the best of both worlds IMO. the 1fz + A442F bus transmission + rear disk + full float axle.
Yes the 1fz tends to loose its head gasket BUT only after it's been overheated. So if you keep the fan belts and cooling system in good nick its just as reliable as a 3f. The added power IMO is worth replacing a head gasket every 6-10 years (its really not more than a Saturday job anyway.
FYI I've bought and sold a 94 FZJ80 with 460,000mi on the original head gasket and trans. It drove as well as mine.
Needless to say, I've converted a few domestic boys into Toyota fans with my '92
