Thanks for the link to the 470 pages of bliss..Saved for a rainy day. Also, I had no idea the ignition switch was set that way, pretty cool
Not sure what Lexus calls this feature but I really love starting my GX up. Not needing to hold the key until it fires up. Maybe it’s cause I came from an 80 that took a couple seconds to start.
Switch or button? There is a button for your TPS so you can switch between two different size tires.I gotta figure out what the little switch way under the steering column is for
I just noticed that the middle piece in the cup holders adjusts to different size cups but still not that good.
G'
Let’s see some more on the attic rack storage.
Also may explain ATRAC problems lol
If you are in 2 not L wheel speed will be higher so ATRAC will work but less so.
What do you mean by "move the transmission lever to the right and hold it when in 2nd gear?" If I'm in 2 and I move the stick right to L, the L on the dash lights up and the stick stays in L. Is the transmission not really in L? I don't understand what you mean by "hold."This whole time I've been off-roading, I didn't realize that you have to move the transmission lever to the right and hold it when in 2nd gear to engage "L". I've been in 4Lo and CDL'ed and in 2nd gear. Yikes, my bad.
I need to try my lever again later today. Last night I just saw the shift position go to L and back to 2, but that was in my driveway without moving.
I probably didn’t hold it or push it far enough to the right to engage and stay L.
If both the shifter and the dash say L, then you are in L.
