The part numbers are color and position-specific. I believe the metal clips are serviced only as part of the handle.Anyone know the part numbers for the "oh-sh*t" handle retainer clip, the plastic insert, and the handles:
I am specifically looking for a match for the grey interior (2013 LX570) on the right hand side of the vehicle (all 3 handles)...many thanks if anyone can find the part number and/or diagram!The part numbers are color and position-specific. I believe the metal clips are serviced only as part of the handle.
Good morning, could I please get the part # for the front passenger side door sill for a 2015 LX. The previous owner bent the one that's in there. Drives me crazy!
Thank you kindly. Have a great weekend!
2018 Land Cruiser, part numbers for inner and outer tie rod ends, both sides please.
I don't believe so, if that should change I'll be back.What color interior trim? And is it the illuminated one or without?
LH TRE Assembly 45047-69146 (includes castle nut and cotter pin)
RH TRE Assembly 45046-69236
Inner Tie Rod (same number for both sides) 45503-60030
Edit: @PhuckItImDone do you need boots and clamps too?
My bad. Illuminated with black trim. Thank you!What color interior trim? And is it the illuminated one or without?
I think one of the OEM clamps is not reusable.. at least by Toyota standards.. not sure if that means you can’t. I just ordered inner and outer and boots and clamps. I found one of my boots torn and figured if I was going to work on them I’d replace it all.I don't believe so, if that should change I'll be back.
Much appreciated, I'd be kicking myself in the morning when I got to this pointJust in case..
Boot: 45535-60021
Small clamp: 96134-52600
Large clamp: 90460-76001
Any time.Much appreciated, I'd be kicking myself in the morning when I got to this point
@bloc can you post the following part numbers for a '21?
PCV VALVE
MAF sensor
air/fuel sensor
o2 sensor (s)
TIA.
PCV 12204-38010
MAF sensor 22204-75030
A/F sensor 89467-53060
O2 sensor 89465-60520
For anyone else coming along and seeing this, there are year-model changes for the exhaust sensors so verify the numbers for your rig before spending money on this stuff.
