i was quite thrilled to see my egt in that range.
That's a LOT of room to turn it up in the top end!
i might just turn down the off boost fueling a bit and see what happens. if i don't like it ill turn it back up and learn to drive with a little less loud peddle
While I agree with @tweeek and others about the EGT being very low, without a comparison, perceived power is relative to the person making the judgment.
Hahaha. I agree.To me that was normal, to a Prius owner, it was evidence of an impending zombie apocalypse!![]()
110km/hr in 25 degree C heat on flat ground 600 F is as high as it gets
It seems crazy to me that you are hitting a max of 600f pre turbo, with ample power, even with an intercooler. That seems way to good to me true IMO. Im tuned relatively conservative, with a max of 1000f pre turbo at sea level, intercooled, with a 16g compressor wheel on stock ct26 turbine at 14psi. I can hit 600f in a playground zone. I would be cautious you are seeing accurate results if you are certain your temp probe is in F and installed pre turbo.
exactly. i think i'm in a good safe range right now. i'm going to tow a trailer this weekend which will push the egt higher for sure. my reason for posting that egt was to say that at boost i'm not over fueling. only off boost i have a little more unburnt fuel than i want.
That is still a rather conservative tune I would say. If your happy with the way its driving on boost, try turning down the no boost fuel with the smoke screw and enjoy.i was doing 120 up a hill with foot to floor into a headwind (and was still accelerating) and got to 800f. i was at about 12-13 psi of boost. it was set to 15 max and i've hit 15 once.
diby 2000. that devil in you is playing with the devil in me!! i wanted a quick fix for my smoke but now i might have to screw around with it more!!If you're not hitting 15psi, either the wastegate is set a bit low, or you don't have enough fuel to generate full boost. EGTs suggest this is a possibility
k so as i said earlier i'm new to diesel tuning. i'm sure my waste gate is set to 15 so i'm likely not getting full boost as my fueling likely isn't enough at full boost. if i turn up the over all fuel screw this will push more fuel through and increase the boost correct? does that mean i need to rotate my boost compensator clockwise to increase spring tension to accommodate for that boost coming on earlier. my aneroid pin is turned to max right now. am i thinking about this right and is that the correct order of things to do?
