Another thought.
Is the limiting factor for the stop leaver and therefore the follower pin, the length of the follower pin itself or is it the free space in the housing for the lever to move?
I think I understand what you are asking @mudgudgeon and while I think you are correct, I would think about it the other way around. The main advantage to a larger diameter aneroid, translating to more follower pin travel would be an increased differentiation between no boost and full boost fueling.
I could have it wrong, please direct me if I do, but I don't think this can make the pump deliver more fuel than what it would otherwise deliver would it?
limiting factor is free space in the housing, the lever will bottom out aginst the housing. you could possibly clearance the housing for a little more travel. it seems even 0.5mm is significant here, so a little clearancing might be worth while. there is a screwed in steel bushing for the guide pin though.
yeah, we are thinking the same way, just describing the result differently.
the greater difference between no boost fuel and full boost fuel is what we are talking about. I think having a larger diameter aneroid puts you at a lower starting point on the no boost fuel setting, potentially leaving more room for fuel up top.
EGTs or AFR is probably going to be the limiter on full boost fuel
), any reading i've done on powering up Dodge Cummins with the VE pump, the pins seem to often have a convex grind, and not an eccentric cone shape, and often starting from the very bottom of the pin, leaving just enough full diameter for the guide pin to touch on.
