- Thread starter
- #1,621
That's my approach.
What's the fun in that?
That's my approach.
I must confess I cringed when you said you slid this solid metal rig into an embankment. I know these Jalopys are designed to go almost anywhere but seeing all the hard work you put into yours, plus their rarity and expense of repairing, wheeling them is both exciting and very unnerving. Mostly the latter for me.
I’m not super thrilled about it myself - but I’ve always gone back and forth as to what this rig is. The sheet metal is in good shape for its age, but as a whole the truck is also almost valueless from a collector standpoint with the engine/power steering/disc brake conversion. The quarter panels are already trimmed, dented in a couple places, and cut for an auxiliary fuel tank the truck never received. I also ascribe to the philosophy that there is no point in owning a vehicle if you don’t drive it. I never set out to build a trailer queen. I bought it to be a fun around town truck and mild off-road rig. I've got the "around town" part pretty well dialed in - but I'm still too low to the ground and too high-geared to really suffice on anything more than green/easy trails. I’m already wheeling it harder than I’d intended (thus the damage) so plans may change a bit but for now - I’ll just take my lumps as they come and wear the dents as evidence I actually drive it like it was meant to be driven!
I have not done a stitch of bodywork to the truck yet - and I always intended to do some, down the road - so any dents now are essentially "free." I was going to do some work there anyway - now I've just created more work.
I've been going back and forth on this myself. The rubber flares will obviously flex out of harm's way which is nice - but I'd like something to take body damage and keep obstacles our of my quarter panels. The rubber flares would survive, but the quarter panel underneath would take the hit.
I'd like to think steel flares would be able to absorb or shrug-off an impact, particularly if I make them out of tube or sufficiently reinforced 3/16th - but my thought, like yours, is that they'd just translate a hit on the flare into the sheet metal. My only counter-argument is that in that area, the sheet metal is substantially reinforced because the flare mounts right where the wheel well mounts to the quarter panel, along with a couple of wheel well supports (except at the lower rear, exactly where I took the damage) where there's nothing structural to back-up the flare. It would be easy to install a frame tie in there if I was really concerned but then I'd have the body rigid-mounted to the frame at that point - and it probably isn't worth it.
Long story short - I don't think either style flare would offer much protection - and with the little skinny tires I run, they're basically just there to cover my hacked up quarter panels.
It would probably be best if I just avoid crashing into things - but so far in my inexperience I seem to be drawn like a magnet to trees and rocks.
I'm REALLY looking forward to the improved gearing of the H41 - as I think my 28:1 stock gear ratio is really forcing me to beat the clutch and fight hard to avoid stalls and maintain control. The truck just wants to roll really fast. The H41 will get me to around 45:1 in first gear. Still not great, but a good compromise between cost, street manners, and offroadability.
Ipor had some steel ones bent up a few years back that looked real good, if i remember they had 2 different widths.. always likes the fzj40 ones..
Great thread! Morning coffee vacation read, it's been fun, sub'd.
. It has been fund driving it, but not that I've started breaking things, it's time to get back to fixing it.An FJ40 with a hardtop at 60 mph is in violation of some law of physics somewhere.
I would say I don't have this issue due to more lift with the SOA. In my previous lift incarnations I had dual exhaust.Well - found one potential point of concern in terms of clearance:
Something tells me my driveshaft has been at odds with my Y-pipe off-road. I’ve been hearing a grinding noise which I thought was potentially my clutch but it only seems to occur when I’m off-camber. I’m wondering if maybe this is what I’ve been hearing. Oddly if I stuff the left wheel with a floor jack, I’m nowhere’s close - to the exhaust or the bump stop, but I suspect if I were to stuff the opposite rear tire I’d have my culprit.
Paging @Cdaniel - curious how you’ve avoided this.
