- Joined
- Sep 9, 2004
- Threads
- 187
- Messages
- 13,329
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
Cheers
Ian, please talk about "air bags" as an option for adopting to different load conditions. thanks, DirkCenter of hood and ARB.
I think it is proper here for proportions and the 285 tire size. Good up and down travel on the shocks as well.
When we build these they are always custom. Coil’s selection always come last. We have tried different body on chassis heights and there are limiting factors as well. Such as where the rear wheel well inner pinch weld lands on the frame. It is the same be it a 73, 77/76, Troopy or even a 60-series. That pinch weld lands on top of the rear frame rails and suspension, you can only go so low without major cutting of the body here. Then you can set the front with built in stink bug (the front body mounts lower) and compensate with suspension to level it all out. We don’t like this method so we carry the body fairly level front to rear when building body mounts.
On the pickups you have much more flexibility as to body mounts and their height since the beds be it long or short don’t conflict so much with the rear chassis and suspension. We are talking exhaust clearances here too when running 3” exhaust.
Due to all this there is no “cookie cutter” on these chassis swap builds. Meaning you can’t say, oh I will just buy a lift kit for 2” that suits an 80 with bumpers. However once you do get the coil springs dialed you just stick with that for the life of the Cruiser. Or…great thing about 80-suspension, want to run 37’s?! No problem, just buy the correct coils, drop the bumps the needed amount and adjust the suspension control arms. Or anything in between too! It’s A LOT easier to play with for all kinds of weight and heights vs leaf springs.
Cheers
Looks like Mission4x4 glass option.What brand of gullwings did you go with? Did you have a bad experience with another company? I pry into this only because I'm getting gullwings this year for mine.
I went with Mission 4x4 glass gull wings on all four windows. Sean, from Mission 4x4 is a stand-up guy, does what he says and he produces quality products. I think his gull wings are a little more robust than the Explore Glazing product and I prefer his method of installation (no drilling holes). I also spent months trying to work with Emu wing, I finally gave up. ( in hindsight I am glad that things didn't work out with them.)What brand of gullwings did you go with? Did you have a bad experience with another company? I pry into this only because I'm getting gullwings this year for mine.
Those are nice !
what brand Ian ?
