- Joined
- Sep 9, 2004
- Threads
- 187
- Messages
- 13,329
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
Intercooler and it’s plumbing.
The Troopy has the small scoop hood, it’s basically the same size height wise and the non-scoop. The 2016+ DPF hoods have a larger scoop. The intercooler Tony bought was for a VDJ79 and front mount. It’s obviously big! 3” in and out on it too. We played with plumbing it with 3” but the main issue is hood and clearance to it at the intake and it’s 90*. So we went down to 2.5” and it just barely clears as you can see here.
It would flow a little better being 3” and have a bit less psi loss across the system but without the DPF hood I don’t think that is possible. All the other FT/FTE builds run 2.5” and it’s a non-issue on those. We have kept the silicone connections to a minimum and kept them couplers vs 90/45* as much as possible. From our experience when you start running big boy boost and have soft 90* and such they can be an issue.
The intercooler is so large it doesn’t clear the stock grill even being a wide nose front clip. It’s a PDI VDJ7x system and I am not sure what they do there for the grill and clearance. Anyways we carved up an old ratty stock grill so it cleared. We then sent that to @kelly saad for him to make a custom grill.
Cheers
Cheers
