4 years into my front DC on a manual 6 litre 4" lift. Still going fine but never again, customer service = zero afther the sale.
Don’t remember the brand name of my DC cages but they are loaded with Spicer Life Series joints. The differential end uses the Matsuba joints. I run DC front and rear knocking rocks on 37’s and have had zero problems.Everything on mine is spicer and according to Marshall Shepard, greasing every 3k is the norm for spicer. I find that absolutely ridiculous and I'll be doing something different
Was it sold to you advertised as Spicer components?Just an update. Shop got the driveshaft apart today. Nothing in the shaft is stamped spicer and the shaft is destroyed. It will need to have the yoke cut off and replaced. I find this absolutely infuriating with a shaft that's 10 months old.
Whats sad is we buy from what we think are reputable companies and we find out we got junk. That's what happens when you assume. I never thought to ask. Assume again.Was it sold to you advertised as Spicer components?
Yes. I'm familiar with over lining and causing it to act like a hydraulic ram. This was not the case with mine. I actually removed the zerks and compressed it just to be sure the two pumps I put in wasn't taking up the last bit of room. Nothing came out when it was compressed. Either way. It was supposed to be spicer joints, nothing inside the joint says spicer. And from what I've seen it's supposed to be labeled. I'm going to cut my losses, replace the dc with spicer stuff and run it. Any other problems and I'm making my own.I believe it is possible to over grease the slip yoke and there's potential for serious damage if over greased. But regardless of that, there are enough cases out there now about the Tatton shafts that make it obvious that quality parts aren't being used and customer service is severely lacking. IMO, nobody should be wasting money with Tatton because of sufficient warning. If you buy one after seeing these bad reviews, you have nobody to blame but yourself.
My front DC from Tatton is still going strong and I am running sled off-road front control arms... so no my front is not pointed at the tcase. My rear blow up a few years ago when I started this thread. The rear was pointed up but not directly at the tcase. I put the factory rear shaft back on and dropped the angle to parallel. I have had no issue with the factory rear shaft. Too bad tatton makes questionable parts.For everyone running DC shafts, have you rotated the axle to get the angle of the shaft joint near the differential to be near zero? For front axles, this normally requires a cut and turn of the knuckles to get the caster right. If the angle of the joint near the diff is not zero, that could cause vibration that will shorten the life of the joint bearings.
A majority of people use castor correction bushings or plates. This is why people run DC front shafts.For everyone running DC shafts, have you rotated the axle to get the angle of the shaft joint near the differential to be near zero? For front axles, this normally requires a cut and turn of the knuckles to get the caster right. If the angle of the joint near the diff is not zero, that could cause vibration that will shorten the life of the joint bearings.
Yes, caster correction plates and bushings fix caster problems due to suspension lift, but they rotate the axle the opposite direction of reducing the shaft angle at the pinion. Throwing a DC shaft at diff that is at the wrong angle is not a long term solution.
With my 3" lift my pinion is now within 0.2° of driveshaft angel which is more or less perfect for theoretical DC driveshaft.The front shaft starts life out in a broken back configuration. So as you rotate the axle to correct for caster the operating angle of the pinion U-joint lessons. If done properly the joint is aligned for a DC shaft and it will last the lifetime of the vehicle. My original 80 has over 100k miles on a modified Tacoma shaft.
technically the ideal setup is 0°, so no movement during operation.With my 3" lift my pinion is now within 0.2° of driveshaft angel which is more or less perfect for theoretical DC driveshaft.
That said, Tom Woods suggested that a 1 -1.5° difference would be preferable as it better accommodates lubrication of the spicer UJ's.
