I am looking to pick up a set of dedicated off-pavement tires for my 62, and have narrowed it down to a few Swamper choices: 32x9.5x15 TSL’s, 34x9.5x15 TSL’s, and 34x10.5x15 LTB’s. I am leaning towards the 32x9.5’s, but would like to hear opinions, particularly from anyone who runs any of these.
This wagon is my DD, so I am not interested in modifying anything to accommodate larger tires. Most of the off pavement will be crude, unpredictable back-country roads, mud, snow and ice (with the aid of chains), no rock-crawling. On-road character isn’t too important, as they would only see pavement on trips out to the hills (I run 29” BFG AT’s on road).
I have an OME med-heavy lift (2.5"), and will mount the tires on a set of STOCK rims. The drivetrain is stock, with 4.11 (4.10?) gears and an A440F (currently turns ~2250 rpm @ 65 mph in OD with the converter locked up). I would like to keep a full spare in the stock location (will hold up to 35” from what I understand).
Here are the specs on the tires, and a few other common ones for comparison:
Tire________weight___tread dpth__tread wdth__overall dia___sect. wdt
32x9.5 TSL__50lbs ____26/32”_____8.5” _______32.3”_______9.4”
34x9.5 TSL__54lbs ____27/32”_____8.0”________33.8”_______9.5”
33x12.5 TSL_60lbs_____24/32"_____10.2"_______33.7"_______12.4"
34x10.5 LTB_58lbs ____22/32”_____9.25”_______33.6”_______11.2”
33x9.5 BFG AT________16/32”______?_________32.7”_______9.5”
235/75 BFG AT________16/32”_____7.9”________29.0”_______9.1”
33x10.5 BFG MT_______19/32”______?_________32.8”_______10.5”
Questions:
Are the LTB’s of lower quality than the TSL’s? By size, the LTB should be the most expensive, but it is the cheapest. Any comparison on how out of round and painful to balance the LTB’s are vs. the TSL’s? Durability?
Is a 33.8” diameter too tall for stock gearing? Or does the slushbox help me out here?
Rubbing with a 11.2” section width on stock back-spacing?
Too much lateral give in the 9.5’s?
Any other good choices to mount on stock rims? (I like the new Hercules Trail Digger MT’s, but no 15”s in appropriate sizes, and doesn’t look like they are available in Canada yet)
Curtis.
Questions:
Curtis.
y'all!
(~$257 US) from one of the 4x4 shops
