Romer, you're an engineer, right? Do you happen to recall what the increase in air density is for each degree of temp drop? I'm curious how much boost your snorkel adds with its cooler (denser) intake air charge.
PV=nRT
Ross, I'm embarrassed to admit this, but I have forgotten what each of those letters signifies. Could you please state what each letter stands for?
Sumotoy,
What the hell is excess air as it applies to the sc setup in our cruisers? As far as I know there is no such thing in our cases b/c the sc is a closed system.
Karl
1. You said my gauge isn't that accurate so any delta is probably just within the tolerance of accuracy. I get that you stated that as your opinion.
2. no clue what your point is, but I don't recall anyone saying the output of a SC is fixed
3. That was suppose to make it simple? no clue what you are saying here either.
Karl
Unless the supercharger puts out exactly engine demand, there is excess,
[/i][/b]
Ken
I use 3% for every 1000 feet in altitude on a normally aspriated engine. Problem, that applies only to normally aspirated engines. For supercharged and turbocharged vehicles, it's more correct to use the formula for Pressure Ratio, which shows how force induction has less of a loss for any given altitude gain....
Pressure Ratio = Pressure Atmosphere + Boost Pressure/Pressure Atmosphere OR PR = Pa + Pb/Pa
So for a super/turbo truck at sea level
PR = 14.5 + 6.5/14.5
PR = 1.45
For a super/turbo truck at 5000ft
PR = 12.2 + 6.5/12.2
PR = 1.53
Since we know that the density of air is 13% less at 5000 feet, we would expect the same decrease of 13% power output on a normally aspirated engine. However, when you apply force induction, the drop in power is less. However, that can actually be a lot less, since supercharger compressor efficiency will vary with engine demand, load, and volumetric efficiency at a given altitude.
Just differentiating between an absolute pressure guage, and a relative pressure gauge. What's on your truck, is a relative pressure gauge, so it should read higher. Whether it does or not is affected by all the other variables associated with absolute manifold pressure (and Density = temp). Most factory turbocharged applications are absolute pressure based. Since the advent of electronic wastegate control, most turbo applications are 99% of engine power up to 10,000 feet. Usually at 10,000 feet a barametric sensor switch shuts down altitude compensation to prevent turbo overspin.
That's a lot of efficiency Ken, I personally don't buy it, but maybe under ram air conditions only. I think you might see a slight difference at high speed (ram air effect) + low altitude. But I see problems at low speed and/or high altitude. If the air is less dense at higher altitude, you would need a larger pipe to create the same positive pressure at the inlet of the SC (or going slow enough, you would need a larger pipe to create less negative pressure). The slower the vehicle speed, the longer pipe friction surface starts to revert back to *more* negative pressure at the SC inlet than a stock air inlet.
Race car engineers like 'directiing' air vs ducting air when possible for this very reason. There is no mathmatical limit to air volume and pressure in a scoop or dam. There is an exact mathmatical limit to air volume and pressure (> temp) in any given size duct.
Remember your WWII era planes used supercharging to produce gains at much higher altitudes than we will ever drive....
Cheers
Scott Justusson
94 FZJ80 Supercharged
Working hard to have some thinking going on here Ken.
My head hurts;
I would like to know a few simple things from people who have installed these:
Horsepower increase?
0-60 times?
Change in gas mileage?
Increase wear on engine (or damage0??
Are the worth it, for some who does not live in the mountains?
Thanks
g
I hate that. If you can't explain stuff so it can be understood than don't post. It's not up to you to make me or anyone else here think. If you explained it so I could understand what you were saying then I may actually be able to have some thoughts about what you are trying to say rather than getting more pissed off![]()
If you could actually explain stuff in a way that would make us think about it, then maybe that would be OK. When your explanations are unclear and maybe only understandable by a very very small % of members here than you are not doing anyone a favor. All your doing is pissing me off by talking down to me.
Go read the post psfpilot made a few back. I understood his explanation and what he was trying to say. He was trying to communicate to me and other forum members. You are trying to "make us think" I am sure you don't want me to say here what your posts have me thinking?
Ken, I'm a nerd, and forced induction is a complex subject. Supercharging has even more black holes....
Ken, instead of sending me this, send me a PM, or an email. A lot of truly interested folks on this forum do. I don't mean to speak down to you, I intend to help tech lists be a resource.
Cheers
There is a mechanical connection between the sc and the engine. The output of the sc does not vary wrt to altitude or temperature of the air, or its measured density. The ecu manages the fuel charge to account for all the air in the system. The ecu accounts for things like temperature and so on. There is no excess air in the system. If there was, the truck would run like crap and the o2 sensors would pick up a lean condition and add fuel.
The magnitude of the boost is however varied wrt to engine load via the bypass valve - less vacuum, more boost. The bypass valve lets air bypass the compressor stage and the sc spins idle; however, the measured volume of air remains the same after the MAF. The sc setup is very unlike a turbo where there may be excess air in a turbo system. For example, at high rpm between shifts - the driver lifts thier foot off the accelerator, the turbo is still spinning and boosting, but there is no need for boost according to the vacuum, so the "access air" is vented.
The operating rpm of the sc is a ratio of the engine rpm.
If one were to plot rpm vs. VE on a chart I suspect that the relationship would be nonlinear. VE has nothing to do with engine load though. Its a measure of how efficiently air is pulled into the engine at a given rpm. Some folks get the head on thier engines ported to improve VE or, in other words, intake air flow. One could use the term volumetric efficiency on an exhaust system too. An exhaust sytem with lots of bends in it has low VE because the air gets compressed in the system.
There is no extra airflow. Consider two cruisers - one with an sc and the other without and both taking on the same hill at the same speed. The sc cruiser will operate at a different rpm than the no-sc cruiser because it has more base hp and thus operates at a different rpm to have the same hp output as the no-sc cruiser. In other words, the additional air is measured by the ecu and more fuel is added resulting in more heat and more hp.
I dont understand this comment. Perhaps you intended to make two comments, but merged the two thoughts? I suspect that you are contemplating the loss of horsepower with respect to elevation. I think that part of the loss can be explained by the partial pressure of oxygen. Take Mt. Whitney for example. The elevation at the top of Mt. Whitney is about 14497'. The partial pressure of o2 at the top is about 40% compared to the partial pressure at sea level. In my minds model of an engine it sees a lean condition at high altitude and decreases fuel and there is a corresponding decrease in hp. The higher up you go the worse things get. I think the change atmospheric pressure has little to do with the change in hp wrt to elevation compared to the change in partial pressure of oxygen.
Karl
