Sun Visors
loving the industrial look of your truck. When my trucks interior goes to s*** i will do the same.
Here is what I have on my 80 which can be repurposed for the 60 which is what TLC uses on their ICON which originally came from a Gulf Stream:
Rosen aircraft sunvisor to replace sagging visor?
image-2269905963-jpg.724349
image-1991066505-jpg.724350
image-2609151867-jpg.724352
image-317693005-jpg.730283
image-2401094075-jpg.730284
Do you have part numbers? And are your pictures on a 60 or 80?I'm reaching my wit's end (pun intended) with the original visors. They look like crap and my passenger side drops down on every bump I hit.
I recently got a set of Toyota beige sun visors from Maarten at CruiserWorld. I'll post up photos and the part numbers a little later. I think they are from a 70 series. Perfect fit in the 60 series and great color match (tan).
Update
Photos:
Fit:
Texture:
As you can see, they fit perfectly. I am very happy. I reused the mounting hardware.
Update
Photos:
Fit:
Texture:
Hmmm...wow....this may be the OEM option I'm looking for.
@red66toy I see your 62's interior is the gray like mine...how close of a color match are those visors in there? How close is the match to the headliner?
I feel like the color is pretty dang close. If its off I cant really tell. My old visors were nasty so those were not a good comparison. The only thing I notice is they look way cleaner than the original headliner and rear view mirror arm. hahaha
Maybe @Kleatus or @NookShneer can chime in, they have seen them installed.
Ok thanks. I can relate to the dirty vs clean effect. I think...maybe...that the headliners in 60/62's are all the same color regardless of exterior/interior color. Perhaps these 70 series visors follow the same universal color scheme. Are they a vinyl type material? The texture makes them appear to be.
Last question....are the two part numbers in the photo above for the Left and Right visor?
Thanks for posting this.
Update
Photos:
Fit:
Texture:
I have those same visors and the head liner material to match. Was loosening the screw the only thing needed to remove the visor? my visors came with the brackets at a slight angle. I have used them this way for a while. great install.
Yeah the material is a vinyl/synthetic material. Not soft organic material. The part numbers are indeed for the left and right visors.
@pandasfj Yeah, you just unscrew the phillips head and wiggle off the old visor and slip on the new one. Then tighten the screw to the desired resistance. Too tight will make flipping the visor hard.
