Steering wheel -- upside down
Wow, I get to tell my funny now, but not when it happened story about removing a steering wheel.
Many years ago I owned a 1968 F100. I needed to fix the shift linkage in the column (3 on tree) and needed to remove the steering wheel. I did not have a puller and figured I would remove the big nut and whack the bottom outer edges of the steering wheel with my hands which should loosen it up so it would come off. Well it came off alright! About 100 mph right into my face! It broke my nose... Imagine trying to explain to your new wife that your truck broke your nose...
Ok now that you all are done laughing some may be wondering what would cause the wheel to come off with such force? Turns out there is a big honking spring in the column that is compressed when the wheel is installed Lesson learned? DO NOT TAKE THE NUT ALL THE WAY OFF! Now granted the FJ does not have that issue with the spring but if you don't have a puller and resort to whacking the bottom , leave the nut on until it's loose!
speaking of not needing a puller when i learning how to drive my father was in the drivers seat going down the iroad saying this is how you use the clutch showing me and all,then out of nowhere he says hold this a minute.guess what it was ?the dam sterring wheel,i s*** you not this young punk myself was cussing his father every word in the book.he was laughing so hard at me he had to pull over.anyway he set me up i did not notice when we left the house the nut was off.kids dont try this at home.thanks i just had to share that.i miss the old bastard
2 min to make. works great.
Is your steering box centered when your going in a stright line? Someone may have done some frontend work and got it off center. Thats how they usually get out of wack.
Was your steering wheel always upside down? Did you make any changes to your linkages? Have you turned the wheel lock to lock to determine the center point? The factory steering wheel and the housing have mating marks for alignment. When you pull the horn cover off, if the marks still line up then don’t pull the steering wheel. Use the drag link to get your steering properly aligned. The Drag Link which is the rod attached to the gear box pitman arm should be used to fine tune your steering column once the steering wheel has been mounted and the two alignment marks match. Before you adjust the drag link, you need to rotate the steering column lock to lock to find the center of rotation of the gear box and adjust the drag link to bring that as close as possible to the correct orientation of the steering wheel when the vehicle is going straight. It will probable take 3-4 adjustments.
Or just disconnect the rag joint and turn it 180*..
You always take the easy way out!
I am lazy like that ;)
Is there an easy fix for a stock 1978 steering wheel that is on upside down?
You could try rolling your rig back over onto its wheels. :D Kind of like the upside down bumper sticker that says "if you can read this, roll me over".
If you go to AutoZone or a similar parts store they will let you borrow the puller for FREE! They charge you something like $20.00 when you leave with it. When you bring it back you get the $20.00 refunded. What a deal! They do this with several of their tools.
Regards...
Yeah but then you would have to flip your bezel
