I'm considering these to replace my yellow OMEs which have been on my 80 for at least 50K miles now.Switched from an old OME (no idea when PO put it on but it felt equal both ways so I guess it was still OK?) to the new Dobinson's Adjustable Steering Damper/Stabilizer (thanks to @Delta VS ). To those who say a damper makes no difference, you should try an adjustable damper! Sure you might not need one to make it down the road but you also don't need running hot water in your house--both just make life so much better!
At the tightest setting my steering wheel essentially doesn't move at all at high speed on washboard and wander on the highway is very significantly reduced. On the loosest setting it equaled my OME in slow compression strength (15lbs to push down on a scale), tightest setting is 23lbs so 50% tighter. This doesn't relate to dynamic performance at all, but is interesting. At >50% tightness it does reduce auto-return of the steering wheel around corners which takes some getting used to but I don't do a lot of town driving so it hasn't been a bother. I haven't found a desire to turn it down to <50% because I just love the stiffer steering, but it's super quick/easy to adjust down if necessary. The Dobinson's promo video has a low/high steering wheel movement shot and it is entirely accurate, driving on dirt at high speed is much more enjoyable and I feel more in control because the wheel doesn't move for "no reason", ever. The biggest surprise on road was the lack of steering wheel movement caused by bumps around corners at speed which makes a much more stable experience, the wheel used to move requiring correction and therefore a bit of rig movement in general.
As for options on the best damper: King isn't an IPF damper so if you're worried about fade it's not a good option, especially at its price point I certainly wouldn't go with a non-IPF damper. The three generic Fox IPF damper options unfortunately aren't quite the proper extended/compressed range for an 80 series so they just don't work. And these are non-adjustable which, now that I have one, I wouldn't bother spending more than $100 without the capability. I think the Tough Dog adjustable is probably the best value direct-fit adjustable damper, but I'm pretty sure it's not IPF so of course it's cheaper. The Dobinson's adjustable stabilizer is ridiculously expensive but the improvement in driving experience on a 6" lift with 37s is incredibly noteworthy and very worth the money IMO.
Delta Vehicle Systems - Dobinsons Steering Stabilizer - 80 Series
Dobinsons shocks are another awesome option for your Toyota
www.deltavs.com
I'm reading Dobinson instructions, but I'm not clear how the steering stiffness adjustments are made.
- Is turning the screw righty-tighty stiffening it up and lefty-loosey the opposite?
- What setting would you recommend for a daily driven 80 on 37s?
- Could this damper potentially put undue stress on the factory steering system including the frame where there's been some evidence of cracks forming nearing the power steering box?
