split case hand/parking brake
Wasilla, AK
Any one running the OEM split case hand/parking brake? Or maybe the Marks4wd t'case brake?
www.marks4wd.com/lc-split-t-ca...-hand-brake.htm
If so, how do you like it?
Thinking of doing a rear disk brake conversion and contemplating what to do about the parking brake. I don't really want to use the elderado or similar calipers with the built in parking brake. I deal with a lot of mud and floating calipers clog up in the mud, loosing their effectiveness.
I have the brake conversion, it works great but it has a conflict with the tubular cross member behind the transfer, I had to relocate mine 2 inches, I have the split case in a 70 FJ40, cheers Larry
[quote author=brew8 link=board=1;threadid=16817;start=msg162555#msg162555 date=1085364754]
[/quote]
Were did you get it? From SOR?
This will be for a 60, so their shouldn't be problem.
Liquid off road and Spector both have the conversion kit.
I bought mine from liquid off road I installed it while doing a rebuild of the tranny and transfer case, Larry
What else will I need if I buy the Liquid Offroad kit? Since I own a 60 and don't have a donor t'case parking brake.
Just a warning, I had some major issues with liquid off road on an order. I don't want to say anything here, but pm me or email me if you have questions.
The kit I got had the new output shaft and the bearing and seal retainer, the drum and the shoes and springs etc, the parts you need are the backing plate the control arms I think there are two, for the shoes and the cable for the brake all the rest is there, Larry
Was being lazy and hoping to bolt something on.
Guess I should make up some templates and build the bracket, need one for the 45 diesel and Toms HZ 60.
Been looking for the mechanical brake caliper, someone said to use go cart brakes?
Any idea who sells this stuff.
Thats what I am looking for, a disk style brake kit. I was looking at the Man-a-fre one, but it is not for the split case.
Radd, if you put a kit together I will take one.
Scott
MAF wants $$$ for theirs, PLUS they want your old drum as a core! WTF?!?
I called All Pro about their kit, they never called back.
Anyone found the Pirate thread yet?
I think the brakes off a 4 wheeler would work well. Or go-kart stuff.
I am interested if someone starts kicking out a kit.
There was a recent thread on PBB about someone using a 4wheeler disc caliper and machining the stock drum into a disc. I'll search and see what I come up with as I am also interested in a parking brake solution.
I used the Liquid off road on my project (currently still a project). The brake shoes didn't fit and needed modified. Also, there is a special seal needed on the output shaft. It wasn't included and it took me awhile to get a part number. The dealer stock 'em.
