I'd run them anyway, ALOT of people run the BOSE 501 on a standard or cheap head unit with no issues. OHM ratings are generalized since the OHMS vary depending on frequency and load anyway.
STOLEN from a car audio website...
There is a way to "adapt" the impedance of a speaker to a different value by using a transformer. However, this practice is restricted to office PA systems and other applications where audio quality is less important. Transformers that maintain high audio quality at high power are extremely expensive, very large and very heavy (in other words, totally impractical for DJ use!). You will find them (transformers) in high end audiophile vacuum tube amplifiers, but the price tag of some of these amps is not that different from a luxury sedan!
Again, you cannot "run" your speakers at 4 ohms in an attempt to get more power out of your amp! (You can connect two sets of 8 ohm speakers (in parallel) to your amp to get more power out of the amp. However, under such conditions the power to any one speaker in general will be less than the amount it would receive if powered by itself at 8 ohms!
