Source for 97 CDL switch?
Prescott Valley, AZ
Slee's out of stock on these....he says it will be a few weeks before he has some again from Japan.
Is there another source for the 95-97 style switches?
I'm currently borrowing one from a 94 that I had to do some modding of the adaptor to connect the harnesses together....but hes going to need his back.
Christo mentioned that the Emergeny Flashers switch might be able to be used...
Is this correct?
cdan should have them, it's where I picked mine up at.
I have two in stock at the moment.
Lance had them last year at Iron Pig Off Road
Uh oh....
Well I have the emergency flasher switch installed temporarily.
It works to turn the CDL on and off.
Now - I have no turn signals.
I'm assuming this is because the flashers button is disconnected interrupting the continuity.
When I found the CDL plug in the dash it had a white blank wrapped in foam in there with a yellow jumper wire connecting 2 pins.
Would that blank work if I plug it in the flashers harness (to give me turn signals again) or no?
Uh oh....
Not sure about the 80, but in my MR2 when I had the emergency flasher switch disconnected my turn signals wouldn't work.
When people are referring to using an emergency flasher switch, I would imagine they'd mean using a second one, not disconnecting the existing one.... :hhmm:
