SonofaB****! Wrong tap used in knuckle threads.
Ann Arbor, MI
So I really boned myself on this one. I feel like an idiot.
After having my knuckles stripped and repainted I finally got around to retapping the threads to get the paint out. The paint is really tough stuff, so I didn't think anything of it when I resorted to using a long handle on the tap to clean the threads on the trunion bearing cap threads, including the steering arm stud holes.
For reference, the studs are threaded with a M12x1.5 in the knuckle and then the protruding stud is M12x1.25
I used the M12x1.25 tap in the M12x1.5 holes. So the threads are definitely good and properly f-ed up. Helicoil is not going to fix this.
Should I try a threaded insert like those from Acme Industrial or Keensert? I know these are ok in engine blocks and similar. Or should I try to get some decent knuckles and start over?
edited to show correct threads; thanks, @beno
My options may not be the best but here is what I would pursue in order of most logical to most insane.
  1. Go to fastenal and see if they have a stud that is M12x1.25 with a break then another 1.25
  2. If they don't see if they have a larger dia. stud to M12x1.25 then drill and tap the knuckles to accept
  3. Get a good welder (and someone who knows how to weld well if you don't) fill the holes, let cool, drill and tap to the right size. This can be done by a steady handed and patient garage mechanic. But you need to redrill the holes in the right spots exactly so your radius arms can bolt back on. It may be beneficial to have your machinist friend help / do this for you.
  4. get new knuckles
I would not use a threaded insert or heliocoil in this application.
Just was thinking about this in the shower, not sure if the knuckles are cast?
But brazing would probably be a better option than welding as you would be able to pool the metal in easier. Thoughts anyone else? I am just a amateur weekend metal worker now.
I just had a close call with the studs shearing and will see this Friday if the threads got damaged. I told the shop if they were damaged to use a new knuckle. I've never ordered from this website but If I can get it for $183, im not risking.
Can anybody confirm the part#?
You should probably contact EB Toyota Parts. They can assist you.
Timeserts work great, Marlin repaired my knuckle with them with no problem. The kit is not cheep but is re usable. Find out how deep the hole is and order different sized insert if necessary. If you don't want to go this way I have a pass side knuckle that Marlin installed timeserts into the steering arm side (bought a replacement knuckle only to find damaged as well). I paid $100 for it and will let it go for the same price with the Marlin repair at no charge.
Amazon.com: TIME-SERT M12 X 1.75 Metric Thread Repair Kit 1217: Automotive
++ TIME-SERT Metric Kits ++ thread repair kits and inserts repair stripped threads damaged threads repaired threads threaded inserts for metal thread inserts for metal aluminum inserts threaded inserts for aluminum
There is another option I have seen but not done. You can drill out the holes, tap, then use Dana 60 studs, then re-drill your arms and it all goes back together cleanly, and upgraded. The studs I believe are 9/16 which is basically 14mm. I'm not sure who got this together, but in the end it worked fine. The owner of that truck is "Calicruiser" but he hasn't been around in several years. I don't know if he ever wrote that up, but it worked very well and looked clean.
Check out post 25 in this thread:
Bronco Canyon THIS Sat.
He says Dana 60 knuckle studs, but it looks like an option to make lemonade out of lemons.
A: The studs where they go into the knuckle are M12 x 1.50.
B: A Heli-Coil or other insert of choice should have no problem fixing that problem.
C: The inserts need to be carefully installed for long life, straight and properly spaced to the arm pattern. Preferably a mill or at least solid drill press, not the place for a hand drill. They are highly stressed, so crooked or misaligned studs may yield them, not likely to maintain proper clamping force.
D: In this type of connection, all surfaces should be metal to metal, no debris between, this includes paint. All of it needs to be removed from contact surfaces, including the cone washer holes.
Are you telling me custom three piece Heli-coils with undersized hardware don't work?
  1. Get a quote for new knuckles thru Work
  2. Get a quote to have a machine shop put in same sized hole inserts
  3. Call Jason at Cruiseryard
  4. Contact this guy on Ebay and make a deal to buy both:
91 92 LAND CRUISER L. FRT SPINDLE/KNUCKLE STEERING KNUCKLE 3610508
LEFT/DRIVERS SIDE
  • Get Drunk and JB*Weld it
After reading all this, I would look around for a new knuckle first. Seems like a lot less work. And then if you want to try *insert repair method here* go for it, knowing you've got a good backup. I personally wouldn't even bother with the backup. :meh:
