Solved! HG done. Now sputtering/puffing/missing.
DFW
So, I'm about sick to my stomach over this now. Spent a lot of time/effort doing my HG job the best I could using Doug's DVD and the FSM. I followed everything as exactly as I could but I think I may have missed on getting the head bolts torque procedure perfect.
Finally finished the job last night, got the rig fired up and everything seemed good once I ran some new gas through it and got the timing adjusted properly. Drove to work this morning, everything felt good/normal. Left the office and headed to the gym and noticed the LX felt nice and crisp, good throttle response and slightly increased power. Got into the throttle some, not WOT, parked at the gym. Going to leave the gym and noticed it feels like the tranny is slipping some. Trying to isolate it, throw it into neutral and rev the engine a little. Engine revs ok without sputter, so I decide it probably time to do the tranny fluid drain fill, the lite version where you only undo the drain bolt and swap ~4 quarts or so. I've done that work and decide to adjust the timing. After screwing with that a while, I walk around the back to a decent amount of steam coming out of the tailpipe.
The only thing I can think of is that I somehow managed to not torque the head bolts perfectly. They did not all tighten exactly the same, meaning some of them made it to the extra 2 quarter turns after torquing with different levels of perceived force. Is there a chance I broke the head? Seems unlikely.
Thoughts?
Running out of options, head is swimming.
Start with simple things. Make sure the intake tube is on good and you didn't crack it. Check the plug wires, maybe one didn't snap on good. Did a wire get on the headers, like the o2 or mad/vfm?
Good point. I'll start with those. Plug wires are fresh, replaced in the last 5k miles along with cap, rotor and plugs. Will continue to go back and double check.
What part of the US are you located? If it is cold it will be normal for a vehicle to emit a fair amount of steam. All the moisture in the air gets sucked into the engine and condenses as soon as it leaves the exhaust system. There may also be some residual moisture in the muffler if the vehicle has been doing short runs. It doesn't sound like you are doing extended miles on your trips. Might be worth going for a 20-30 mile run where everything can get up to normal temp and then see what you got.
San Antonio, TX. Currently about 48F and has been pretty chilly. My commute is about 15 miles or so, would that not qualify?
Also, no CELs currently shown. It had shown the CEL for P0402, the bad cat converter code so the little lamp in there still works.
I'm guessing that would qualify as damp and cold. 15miles might be a little on the low side especially if it is stop and go traffic. Also in your title you mention spluttering and missing but have no mention of either in your post. Did I miss something?
I would be sure something didn't fall off a fitting or something. It could be an air leak. I wouldn't worry about the steam yet and I would drive it for a bit and send the oil into Blackstone before I ripped it open again. I have quite a bit of exhaust in the right combos of temp and moisture in the atmosphere and it often happens around those temps you mentioned.
Water is a normal byproduct of combustion, the length of time that water, or steam remains visible is dependent on how long it takes the engine to come up to operating temp, and outside temps.
Got it. Will reread FSM on how to check that stuff out properly. Appreciate the help. Will update when I've been able to dig into it.
Check wire connections at injectors; check for leaks at injector; check compression.
^^^^^ Agreed. Not time to panic (yet).
As instructed above....check connectors for injectors, they get brittle and break easily. Checking for leaks (injectors) along the fuel rail and intake is easy enough, just do a visual inspection. Often you can smell the fuel if you have a leak there as well. IF you've somehow lost 'spark' on a cylinder you will have a 'miss' AND white smoke from the tail-pipe (especially in cold weather) because of the un-burned fuel from that cylinder.
Lastly, do a compression check if you don't find a problem with something else first.
That feeling is the worst. Seriously - I know your pain. That said, if you meticulously followed directions, its unlikely you improperly torqued the bolts. Some schmoo in the block might have caused the feeling you experienced during torquing. If the coolant levels dont change much othet than normal variation due to temp (after ensuring youre burping out all the air) then its probably condensation
I would double check the connection and fitting of the number 5 injector could be leaking or not making proper connection
Appreciate all the responses. I think I have a plan of attack for the AM. I should be able to get to the connectors by pulling the intake off up until the throttle body. I'll pull the connectors and check that they have good enough contact. I did replace the injector connectors as all except injectors #1 & #2 felt very brittle and/or cracked during disassembly. I believe I must have just jacked up that one connector but I'll have to leave you in suspense until tomorrow.
Thanks again for your help guys!
If you break a clip you can dab a little rtv on the plug then put them together the rtv will hold it
Did you just get a PO305 code, or did you not clear it out from prior to HG job?
If you're home with it now & it's where you did your HG, have tools, etc - I'd run it & get it good & past self-cleaning temp.
You're bound to be hypersensitive right now, and only you can judge how well you think you torqued the headbolts - but unless the system has antifreeze in the coolant & it's smelling sweet in the exhaust, I'd expect the steam since it's a byproduct of running the motor.
Just a P0305, cleared codes prior to startup. It ran for a little while without any codes at all. Only code before HG was P0402, the cat conv code.
True on the smell although I’m currently running distilled water to clean green stuff out of the rest of the cooling system prior to refilling with the good stuff.
