What’s up y’all?!
Found the problem and another solved another potential issue. First, when I replaced the injector plugs, I mangled one of the contacts a bit during removal from the old plug. After pulling the new plug and checking the contact, it was just skewed enough not allow proper contact. It got back in there and straightened it out with a pick and screwdriver. Fired back up, cleared code stayed gone. Stutter is gone, just nice smooth power. Coolant levels are consistent. Smoking was steam on start up, I was just being sensitive as was pointed out before. All is well. Damn that was depressing for a minute there.
Another thing I had found that according the FSM could cause similar symptoms and codes was a loose connection to the alternator. When going back over my work last night, I found I had forgotten to tighten that down post rebuild.
Next up, tranny is shifting a little abruptly. Think it has to be due for a full tranny fluid change out.
Thanks again for all the calm advice!
