- Joined
- Jul 6, 2003
- Threads
- 43
- Messages
- 133
I've decided to go SOA.
I've read and will continue to read all the tech links on this procedure.
Here is what I've come up with and a couple of questions that I couldn't find answers to from the tech tips.
I'll be doing a cut and turn on both axles.
I'll be using stop springs with add-a-leafs (man-a-fre).
I'll be making my own traction bar from (I believe Woody's, but there's name on the article).
Hy steer steering arm from aqualu.
SOR spring perches.
SOR brake lines.
SOR U-bolts.
Questions:
Pipe cutter? I will use a pipe cutter (becuase I'm anal and don't have the patient or finess to use a grinder), does anyone have the brand, model or better yet part number for a good pipe cutter that is up to the task of cutting axles?
Angle indicator? Same... brand, model, part number...?
Center pins? I can't figure out how exactly these tie in to the whole system but it sounds like I mine as well use new pins...?
Shims? I've read about them being used for longer shackles, but will I need these with a cut and turn?
CV Joints? Will I need a CV joint in the front? A good source of supply? Part numbers...?
Finally, drive shafts...? I don't want to cut corners on this project, however I'd like to reuse my drive shafts so that I can drive my truck on the road untill I have enough money to buy custom shafts. I figure if I don't go four wheelin' I'll be good, as long as they reach when the truck is sitting on pavement. Will this work? or do I need to get new shafts reagardless?
Please let me know if there's anything else i'm missing. I'll continue to read and try to figure all these logistics out, but I would appreciate any of your inputs.
Thanks,
mike
Merry Christmas.
SOR spring perches.
SOR brake lines.
SOR U-bolts.
Questions:
Thanks,
mike
Merry Christmas.
