SOA Preps
I run Toy mini front CV shaft in the rear but stock style shaft in the front. I see no need to even worry about a CV in the front. How often do you need to run at highway speeds in 4WD. I never do.
Shims - Do the job right and you won't need 'em...
Add-a-leafs - Why? With my saggy old stock springs I have plenty of height for 38.5s with a bit of trimming in the rear. With spring flip you'll be trimming anyway so...
LandCruiserPhil said:
Pin_Head I could just be confused by your wording but when it all said and done you want to end up with Postive caster.
Yes, I stand corrected. The top of the knuckle is angled rearward, and this is positive. I did front end alignments for a living for two years, but that was a long time ago, so I forget +/-.
I used 2.5" lift springs with mine and did cv's on both drive shafts. there are many advantages to the cv's including the ease of setting up you pinion angles. also having the pinion pointed directly at the tcase give you less likelyhood of rotating it under load to the point of bind and pinion failure. they are also cheep to build. find a local shop that lifts a lot of mini trucks and get some of the discarded front cv shafts mate these into your LC shafts (tube size is the same) and you have cv shafts for less than $75. I have also heard that the dodge d60 spring perches are stronger than the MAF ones, but I am not sure. I cut mine off very carefully with a plas and re used them, but I would not recomend it. BTW I did my own cut and turn and it seamed pretty straight forward. I used a sawzall and marked the blade to keep the depth at a good level and it went well.
Over all the biggest tips I would give are to not be afraid of the task it's not brain surgery, and to measure multiple times before every move. You'll never regret spending the extra time to get things right.
one more question then . since you guys are talking toy cv i think we need some info on years of vehicles to get the donor shaft from . i did a cv on my buddies i would like one day to change mine to a cv . but i have run mine this way for 6 years . (no cv) also daily driver for 4 of the 6 years doing over 80 km back and forth just to work every day and never had a problem . anyways back to cv's isn't there a few different ones ? different bolt pattern ,one that has more travel in the cv ,also toy minni front shaft has a longer slip yoke than cruiser (plus for shackle reversal) what about landcruiser cv's ? whick ones are the best to use ? the one i used on my buddy cruiser set diff pointed at transfer case .had a different bolt pattern than cruiser .and the cv binded up when the suspension drooped . ended up destroying the cv shaft . the cv didn't have much angle trough it . stock u-joint could handle more droop than the toy cv we used .
SO WHAT YEARS HAVE THE BEST CV'S TO USE ???? need more input than just use a cv .
but i know some guys have not used cv's how about the magnificent mudwiser ,no cv ,norcal marauders club ,seen trucks with no cv's ,also danny warden used to do sprin-over conversions with no cv shaft ,so it can be done right with no cv . cv is just easier to set up .
Jake
Captain said:
I got a complete cut and turned housing along with a shackle reversal kit from Jeremiah with Proffitts Cruisers. He was excellent to deal with and didn't seem to be bothered at all by my huge number of calls to him for guidance.
http://www.proffittscruisers.com/
Ditto. I'd use Jeremiah again and highly recommend him. My only suggestion would be to get the front axle without the spring perches welded on. Get the perches, but weld them on yourself to make sure the angle is correct. I also used his shackle reversal kit.
I ended up using CV's front and rear. Because of the H55F the rear shaft was rather short, about 18 inches. I used early FJ60 front shafts and had them shortened/lengthened.
I got my CV from an '84 or '85 minitruck front application. slighty enlarged the holes on the CV side and it slipped right over the studs on my park brake drum. I had a local guy splice the CV end onto my existing rear shaft to get the correct flange pattern on the rear pinion. My pinion points straight at the T case and there is no vibration this way. My 40 is the slowest one on the planet and i rarely see 70 mph. no vibration at any speed up to 60mph though. I haven't balanced any of the tires either and there is zero vibration at speed. Cost for minitruck shaft was like $45 and a 12 pack to have it spliced to the stock shaft.
I still need to weld a higher fill plug on the rear diff, but first the rear axle seals need replaced for that to do any good at all.
I didn't cut/turn the front, get some crappy angles at full droop but so far not any carnage - it will happen at some point I am sure. Might do a cut/turn here soon depends if I have the ambition to pull the axle when I rebuild it or not.
I used the stock springs and pulled a leaf to get less lift, now i need an add a leaf in the rear because i added a bunch of weight to the rear with my bumper, tire/cooler, fuel tank, rear seat, and storage drawer. My weight bias is all jacked up but I wasn't shooting for a comp buggy. I don't think you would have any problem at all doing the cut/turn yourself - don't know your skills or shop/tool availability though. I am always impressed with guys who pull off major mods in thier driveways or garages - I really take our farm shop for granted. I have always thought shipping an axle housing would add a ton of money to the shop fab route, that's why I haven't broke down and had a shop do my front axle.
With a shackle reversal the cut/turn becomes almost mandatory - I know because I haven't done it - the pinion drops away from the t case and makes things worse not bettter as is the case with stock, front shackle location. I would reccommend the SR because of handling and the opportunity to easily increase wheelbase. My SOA, SR, Saginaw PS handles and rides at least one hundred times better than it ever did in stock form. There are always drawbacks and tradeoffs to any mods but i am a firm believer that these three mods are the cheapest and easiest way to get a lot more satisfaction out of your rig every time you drive it. Good Luck
One other note -
I don't have much slip travel in the d shafts i recycled from the stock rig. My front shaft falls apart in regulary if I ever back down something. I haven't experienced any trouble with the stock rear slip.
I think I'll end up getting shafts from SOR or having custom one's made.
After reading everything I could find on the SOA I've now convinced myself I should look into the PS too while I have everything apart. So now:
Has anyone just used a peice of solid stock for the steering shaft? All the shafts I can find on the web are like $200. Some of them are "slip yoke" which to me means it can extend and shorten as needed like a drive shaft, I may not know what I'm talking about, but I don't see why a steering shaft needs that....?
A peice of round 3/4" stock with u joints at either end should work and I could make one of those for $20, plus the u joints.... what's wrong with that?
hi have power steering and am using solid round bar and two u-joints ,i would like a slip in there
but am on a budget also . i have had no problems . thats how advanced adapters and downey ps. kits used to come. ( solid bar with no slip) later jake
p.s. get custom ones made (shafts)
You need slip travel to accompdate frame flex and isolate minor vibrations. You don't want to push the seal out of your PS box when the firewall moves in relation to the rest of the frame. The body mounts allow for flex, you have to have slip travel because things move around enough to bind up.
Round stock without machined flats or hex patterns will be hard to lock down in your u joint. You don't want to take the chance of the steering shaft spinning inside the joint yoke. depending on the year and model of your PS box, there are many options out there for sourcing specific steering U joints.
I am refering to a Saginaw style setup, i know nothing about the Scout or Toyota styles. Lots of very good tech links here about all styles.
good point i would go for slip shaft . my sag box did get its seal eaten . its been like 10 years though
and i'm on my second seal on my second box . my ujoints are welded solid to the shaft . i think slip shaft also has something to do with a front end collision . gives some compression to the steering column so that it doesn't get shoved through your chest . i've always been scared of eating the steering wheel if i get in a accident . i think you need some kind of collapseable steering collumn for safety also
I contacted Borgusen directly and told them what I was doing (saginaw) and the sent me everything ( Adapter, 12" shaft, u-joint, slip shaft, and the last u-joint) for a little under $200.00. I asked him about a spud shaft for the $80 - $90 that everyone is using and he laughed. That's where the adapter and a 12" splined shaft came from.
I did exactly what you are thinking, except I am using pipe. I used a ps box from an s-10 and i took it with the first piece of the steering linkage. it had two "universal" joints. they are sloppy and dont look as nice as the bling $200 ones, but it workes fine. I hooked one end up to the steering output shaft then lengthened the middle section with some pipe that fit tightly over the shaft, then hooked the other end up to the steering box. works great. there is a little freeplay, but overall it works great. has much less play than the original billion link setup that came from the factory.
I was also able to mount a york compressor above the power steering pump on the drivers side. this involves setting the pump very low and the compressor clears the hood by only 1". I would recomend pulling the front clip as well as the rad. + mounts and then you will have lots more room to work and you will be able to check hood clearance easily.
i don't know if this subject is dead yet, but i haven't read where anyone referenced a disc brake mini truck front axle in the mix. does this change anything about the soa conversion? is cutting and turning a mini truck axle any different than a fj40 axle?
