SOA opinions
Rixeyville, VA
Surface rust and leaky knuckles aside, can i get some quick opinions...found a 40 that is in great shape but wasnt sure how well the SOA looks.
I'm ok with doing some stuff to make it work better but i just want either a "Run away as fast as possible" or " its ok"
thanks
looks okay from the pictures, drive it jump it and see how it drives
Thanks,
I claim to know nothing about SOA's and/or doing them properly. I just wanted to make sure there wasnt anything that should make me totally avoid the truck. Mechanically the truck is awesome, body is almost perfect and it has power steering so i can deal with some minor steering issues if there was anything wrong with it.
Just a thought, but did you read the SOA FAQs here to see how a correctly done SOA should look? You could compare that to the rig you are looking at.
http://www.ih8mud.com/cruisertech.php
I'll be the first to admit I don't know much but I did read through the FAQs awhile ago and I remember something about cutting and turning the axle to do it right. In the pics it doesn't look like the axles had that done so did they use shims?
Just my $.02 worth...
That looks like someone actually did a pretty good job with the SR and SOA. The pitman arm looks like a custom piece, a little on the thin side unless the picture is distorting it. What does the front of the frame where they did the SR look like?
Nothing terrifying from the pictures, looks like a pretty standard issue job from a few years back, you may want to update the steering to a modern hysteer eventually if the rig is to be wheeled. If the housing hasn't been cut-n-turned you may want to do that too, makes them drive much better down the street as well as gets the pinion out of the rocks.
