Slee Interior Tire Bar Mount
Missoula, Montana
Hi I thought I would show some pictures of the Slee Interior Tire Bar Mount. I was tired of dragging the spare through the snow.
315 Duratrac's sit about 10 inches from the interior panel to about about 23" into the middle of the truck.
I have a question for the guys that have one of these, did you mount the tire off the floor or sit the tire down tight to the floor.
It seems like you get some vibration with the tire off the floor and I was not sure if that would stress the upper mounting bolts to much.
:grinpimp:
Seat that tire firmly on the floor. It will make things a little more solid.
The interior looks great!
That is what I thought I would do, is sit it tight, I put a piece of 1/4 plywood under it to keep the tire from rubbing a hole in the carpet. She is a clean one, Thanks
FWIW...I have a different set up, but my spare sits right on the carpet and it has for about 4 yrs now and zero carpet wear.
Not that great of a pic, but all I had on short notice.
That is a pretty sweet setup, Hanna?
The Slee pole does have a lot of space between the panel and the pole, but a basket would work really well, what do you put in there?
I was thinking the tire would rub through the carpet, but maybe not, really tough carpet. Maybe I will forget the plywood for a while and see if there is a problem
Either way you should be good with or without the plywood.
As for the basket, it is a Hanna. I love it and deeply regret not getting one for the drivers side. I store a tool bag day to day. On road trips I keep the tool bag and a Scepter 20L MFC in it and when I camp a keep two 20L Scepter MWC's.
Have you seen these? The tire rolls straight out the back. It does not have to tip over sideways to clear the mounting studs (which means you don't have to unload your gear if it is totally loaded for a camping trip). The tire is only 3/4" from the fender well to take up the least amount of space. Tire cannot rotate around the pole when wheeling hard. Rack has two steel plates on floor to keep tire off of carpet. Bolts directly into the eight 3rd row seat bolt positions. Can carry a 37" tire just fine. Trail proven for over 50 wheeling trips, including 2 years of Cruise Moab. Shelf over fender is well suited to carry tool bags or whatever, and it is a perfect fit for a Puma compressor, which, IMHO, is the most cost effective method of unlimited trail air.
This is the second batch he has made, but so far he is selling them all locally. If there was enough interest, maybe he would make another batch for shipping out. John
i like the slee stripper poile mounts. i want one to mount my hi lift and my Co2 tank to.
Inkpot, ever get a price on these?
further down in the thread is says $300
I'll be bringing one back from AZ to LA on the plane two weeks from now :hillbilly:
I made one that uses the rear seat mount holes and it locates a 35 inch wheel up off the deck by 4 inches and 6 inches closer to the window. You get more usable room and a better rear view with this. I posted pictures of this on another thread.
I went with the Slee, because "Black Rino 13" had a tire mount for the bar for sale, and it was a simple solution. No doubt some of these other mounts are really a better mouse trap, but I like the pole, simple and solid, and I have it finished :grinpimp:
Here's the one I just sold out of the truck I just bought. Cleanest and simplest one I've seen to date. I probably let it go on the cheap side for $150.
Nice design! Do you know who made it?
Not sold on the long term structural integrity of that design. The 3rd row brackets, on the wheel well, are not that strong, have been torn off.
attachment.php
attachment.php
attachment.php
attachment.php
good point but i bet a few MIG or TIG beads on them would eliminate that worry
