shocks , shaft up or down?????
the theory is that the moving part of the shock (shaft) should go to the moving part of the vehicle (axle), but some shocks are not designed to run that way.
I don't think it matters, but I believe the instructions that came w/my 5125 said to mount them w/shaft pointing down...
It's a Bilstein thing :D
manny
Mount the fronts shaft down and the rears shaft up. Then it'll depend on how you look at it.
Don't know if it is any help at all, but this figure from Toyota (via Specter) seems to show them Shaft down.
That would seem to make it less likely to get crud collecting in the cylinder.
Actually, that shows it mounted shaft UP. The shaft is under that metal dust cover. If you have stock style shocks like this, it definitely matters!
I say mount all others shaft down to reduce the unsprung weight of the axle. That's the way all the racers do it. That way your cruiser will corner and handle much better. :D
The reason off-road racers mount valve body up is for mounting the remote reservoir to the frame and to get it up out of harms way.
I see. Thanks!
That has to be the world's gayest truck. Lame.
I'm still trying to understand the point of putting that much money and effort into something that will NEVER be seen in within 100 miles of a trail.
What a ugly POS, I just put Bilstiens on my bronco, I called and they said it didn't matter. I do know you don't want to mount ranchos or cheaper shocks upside down. You will love your Bilstiens :) :)
