You can leave the swing arms off to make it lighter, then install after you have the shell mounted. The shell isn't all that heavy, its just awkward because of the angle and you don't really have anything to get a hold of with your hands.
lumbee1 said:Received my bumper kit today. I was looking at the instructions that Luke provided 4x4labs rear bumper build
My main bumper shell does not have holes for the spindles to drop in. I got the double swing out kit and while I have a welder, I don't have a plasma cutter for 3/16" steel.
Am I the only one?
Thanks @Convoy. I'm going to need those measurements. I'm not looking forward to drilling those holes.Bummer, call Luke or try a metal hole saw and some cutting oil. I can take pics and measurements if you need.
Ok, I'll post the info this evening when I get home.Thanks @Convoy. I'm going to need those measurements. I'm not looking forward to drilling those holes.
All measurements were on the truck, the 3rd pic is of the pass side hole. The rest are drivers side.Thanks for posting this, it is kind of a bummer that the holes aren't drilled as I suspect most people don't have a 1 3/4 hole saw lying around...Anyway, is that 3/4" from the back?
My main bumper shell does not have holes for the spindles to drop in. I got the double swing out kit ...
Luke is hooking me up and sending a new bumper shell with holes. I need to review my inventory list and make sure I have everything else.Have you contacted Luke? Sounds like you got a poverty pack crossbar, the swing crossbar should have the holes.
