Rusty old bolts!
Tony_Farson
Club President Emeritus, Battle Born Cruisers
Reno, NV
Website
battleborncruisers.com
So how does one remove these rusty, weather worn bolts? I think they're supposed to be 10mm, but the wrenches and sockets won't grab onto them. 9mm, 7/16, 10mm... Nothing works! I plan to replace all hinges and hardware, so I'm about to break out the Dremel and cut the bolts off.
full
I nominate this for submittal to the PO hall of flame. :bang:
Can you get to the nuts?
Under the hood yes. There are no bolts under the dash, at least on the passenger side. I was able to get all but one nut loose and that one nut is mangled beyond repair. I know I'll be cutting that one off. The ones in the tub are of greater concern at the moment.
Other options:
Drill down from the top with a 3/16" bit and use an ez out.
Or, drill the head off with a 1/4" bit (don't drill through the hinge), there should be enough of the bolt to grab with vise grips.
The welded nut procedure usually does the trick But if you are worried about heat, try a die grinder with a real small diameter cutoff disc to put a slot in the top of the bolt (as long as there is enuf head protruding), use a flat screw driver to extract it. If it does not budge, tap on the outside edge of the groove both ways (tighten & untighten) and hopefully you have been soaking them in penetrant too. Practice on the one that's slotted already. GLWR.
The sureshot will probably be the welded nut trick.
Is any of the bolt head above the plane of the hinge? If so, you could grind the taper off your socket. Doubtful, but maybe then, it will grab enough bolt head.
