Runs Like Crap
Chicago
bought a 79 fj40 in january, it was running perfect, the other day i had the oil and filter changed and new differential fluid. now it runs like crap, when i try to accelerate it sputters, and sounds like it is going to stall. can someone give me an idea of what might be wrong. or what adjustments are needed, thanks.
Was it running fine before you fooled with it?
Hard to believe that changing the oil would have anything to do with it running bad, but check the high voltage wire coming out of the coil to see if you knocked it loose changing the filter, since it is in the vicinity.
Check your distributor and spark plug wires. It may seem unrelated but your points will go out and you can search everywhere else without success, then find your points went bad after about $300 worth of new stuff and diagnostics. Happened to me. Cheers!
Pin_Head said:
Hard to believe that changing the oil would have anything to do with it running bad.
unless it was a Jiffy Lube job :frown:
my last time with them while traveling across the US, when changing my oil, when they removed the air filter (during their 40 point :censor: service) to try to upsell me $40 on on $15 air filter a monkey could change, they forogt to hook back up the air intake hose and his description is exactly how my car acted. sputter, stall, etc. put it back on, tightened it down... good to go.
74fj40 said:
it could be possible that not enough oil was put in. whe i was first putting oil in, i thought maybe about 4-6 quarts. but it took a good 8 quarts to fill it up..
A Land Cruiser will have oil pressure with two/three quarts of oil....
I would look hard for a loose vacuum hose or krapinzecarb.
check your hoses probably one not connected, should learn how to change your own fluids, save a headache or two
