lookin good ... you have a tire iron ??? to cut em up some it'll make em hook up better you pay frt to and fro I'll let you use mineweld up that rear end for round up too
Wow didn't know you had lockers front and rear ... Bring It let's roll her over
How does it feel with the 4.56s?
oh yea, Fiona has been double locked for goin on nearly 2 years now.
dont know yet, i did some number crunching and it should be comparable to 33's with stock 3.70 gears. so IMOP not great but manageable. I need to finish up the ram assist before i can drive it, but first i wanna set my alignment before i weld the ram to the tie rod.
I think i will work on it tomorrow some as it will be in the 50's and not below freezing all day, so maybe ill set the alignment, finish the ram then mount my rear lower shock tabs. oh and then im supposed to lower a friends cobalt.
I do 80% of my wheelin in single low and second gear which should be about your 1st in low range it's not bad at all
So are you saying that a doubler really isn't necessary? I find that my setup needs to be a bit lower, but I'm not sure I need 200:1.
Hmm... Last time I rode with you your cruiser went clunk clunk clunk dead spewwwwww oil...
that is why you cant ride with me anymore
your bad luck on that trail... I ran it 3 or 4 times no problem till you came alongthat is why you cant ride with me anymore
and I seem to recall your truck broken and the entrance to the trail
