Replace knuckle? Opinions please.
PNWTreeOctopus
Saint Paul, MN
I just finished tearing down my front knuckles this evening and I discovered that my Right knuckle has some huge gouges on the machined surfaces. I also have a sheared knuckle arm stud to remove and replace. I’m game to try and get the stud remnant out and a new one it, but the knuckle seems like someone abused it. Opinions please!
File the high spots flat and run it There is no critical clearances there. Maybe a little RTV on the spindle mating surface to insure that it wont leak knuckle grease.
Very helpful! Now to get that sheared stud out! Thanks everyone!
drill the center of the stud and then try one of these things (search on google, they are reverse rotation as they screw in, you may want some penetrant or heat on the knuckle.
Irwin Tools 53545 Spiral Flute Screw Extractors
Thanks cody c, I’ve been reasearching this process a bit here on mud. I’m not overly worried, but it does sound like a worthy challenge. I’m picking up the extractors today and some high quality bits from my local hardware store. I’m fortunate enough to have a small drill press to work with. I’m going to update in my build thread.
I'm going to recommend the left-hand drill bit and extractor set from O'Reilly's. I got one and the bits are top-notch and are left handed so they work well to unscrew as they drill.
https://www.oreillyauto.com/detail/...yota/land-cruiser?q=screw+extractor+set&pos=1
Thanks for the recommendation ! I live pretty close to that store. I’ll swing in and Check it out.
Well O’Rileys no longer carries this despite it being listed. On to the next option
Just not in stock or wouldn't order it?
Depending on location, they can frequently have something in a few hours.
I know you're trying to get this back together and don;t have time to sit. The stud is not hardened. If you can get hold of it from the inside and turn it, that may help, but don't booger the threads on that side, it still has to come out the bottom.
Mine had one broke off and two more missing, and the fourth was only holding on 2 threads when I caught mine. (Lucky!)
I chose to clean it all real well and then use Loctite Red to install and I torqued them into the hub at 40 LB-Ft or something like that. Lots of controversy here about torquing them and using Loctite on them. Your choice. I chose to Loctite mine since the studs were missing and it may have wallowed out the threads.
Make sure you use a deadblow hammer to beat on the steering arm while torquing the nuts on these studs at final assembly! (71 LB-FT) That is the biggest reason they work loose, and make sure those surfaces are DRY when assembling where they mate.
This info is exactly why I’m here at mud. Thanks!
Personally I would do two things besides extracting the busted stud. I would place a small amount of weld in the gouges and then grind both surfaces flat with a bastard file.
Why would you put that much effort into it? The steering arm just needs to be able to sit flat so the stack can remain tight on the studs.
The big marring is on the wiper side, not the spindle, so a fat piece of felt and some rubber is going to cover it up.
The hellfires are a whole knuckle replacement project that starts at $1000 and require lots of other mods parts to make it work. Seems like overkill, but I did solicit opinions so cheers!
Yeah, we really don't have any hang ups with spending your money, but your right, they are less than cheap. Then again, buy once cry once...
Later when you want caster correction you can do a cut and turn instead of caster plates or bushings, and a CV upper joint.
I agree with above.
The only other thing I would do is give ruff stuff a call and order the hellfires or whatever they're called now.
I don't know of anyone who's broken an OEM 80 knuckle. I'm sure it's happened but I haven't heard of it. So... not sure these are worth it.
I had some similar problems, I would buy a set of studs all the way around and nut's clean everything really good and install new studs with lock tite at the correct setting , studs are 45ftlbs and nuts 71 ftlbs
