Replace knuckle? Opinions please.
I don't know of anyone who's broken an OEM 80 knuckle. I'm sure it's happened but I haven't heard of it. So... not sure these are worth it.
How many people do you know with knuckle studs/steering arms, that have worked loose, or bent low hanging tie rods or drag links in the rocks?
But, hard to argue with your point: is the $1K worth the gains for the HF knuckles.
Personally I would do two things besides extracting the busted stud. I would place a small amount of weld in the gouges and then grind both surfaces flat with a bastard file.
What does it achieve besides adding a lot of localised heat and stress at steering arm mating surface?
The steering arm/knuckle connection does not get sealed. It just needs a flat, clean, dry connection.
The worst of the damage is on the other face. The rubber and felt knuckle wipers sit down in the recess. The only thing that sits in that surface is the pressed metal plate that retains the felt and rubber. Again, it doesn't need to seal.
None but I dont hang out with 80 owners
Why would you put that much effort into it? The steering arm just needs to be able to sit flat so the stack can remain tight on the studs.
The big marring is on the wiper side, not the spindle, so a fat piece of felt and some rubber is going to cover it up.
I wasn't suggesting to do anything other than grind down high spots on the steering arms surface. I was referring to the felt/rubber mating surface. Not essential, but those gouges would both me so I would fix it.
As above, not talking about the steering arm mating face, I am talking about where the damage is.
I would probably just source a new/used knuckle at that point and sell the old one to offset the cost.
Sell an old, damaged knuckle to........Whom?
What if I told you there were people out there who are more interested in function than appearance?
I’d buy that knuckle, once the steering arm surface was filed I would have a reliable replacement.
I have some used spark plugs, distributor cap, and rotor........Are you interested?
IF (big if) you want to do anything about the gouges--after grinding down the high spots, fill the low spots with JB Weld and sand flat. Easier/cleaner than welding, easier flattening, and will "seal" just as well as anything.
Yeah but... That is totally pointless on the top of the knuckle. There is no gouges big or long enough to form a path for grease to flow either.
If it was a flange that was sealing coolant, like an elbow bolted on the block for an outlet to the radiator, or something with a flange containing fluid it might be helpful, but it isn't, it's a surface between structural/mechanical components which hold back no pressure, you could argue that grease could sleep through but the trunion pin blocks most of that, and as long as there are no high spots (as per other folks mention of taking a file to clean up high spots) there is no need whatsoever, the knuckle cap studs and trunion pin are the only relevant components there as I see it.
I have a knuckle I'll sell you cheap and save yourself a headache.
What are they worth 50 bucks obo. Maybe I can fit it in a USPS flat rate too to keep shipping low.
Otherwise I would center punch that broken stud in the center. Drill all the way through with like a 1/8 drill bit and then move up to a larger size. Once there is a decent hole and a small amount of sidewall left work it out with an easy out or try a chisel to split it.
I agree with above.
The only other thing I would do is give ruff stuff a call and order the hellfires or whatever they're called now.
The Hellfire Knuckles are sold as [Off road use only] from what I under stand they don't behave well on the street.
Trail Gear and some of the other Vendors have the ARP hub stud kits available. They should go a long way in avoiding future sheared off hub studs
File surfaces- holding file perfectly flat- remove all HIGH spots- will be evident when file makes contact with machined areas while being held flat. if it makes you feel good jb weld the low spots then file flat again.. good as new.
If the need arises, I can put you in touch with folks that have broken Dana 60 knuckles... :)
Fake news, dana axles can't be broken!
