Build Removing SBC conversion, going back to Toyota. 1972 Frame Off
WOW that looks good! FYI at one point I think I gave someone we both know my rear drum brakes from my 40 when I changed to disc.
Good luck running the new brake lines. If you stay with drums I have the stainless steel flex rear lines since they were changed.
LMK
Thanks Matt, I appreciate the comments and help.
I have the iron pig ss flex lines that we ordered with the lift. I had a hard time deciding which way to go with the rear brakes. I used one of your rear drums and backer plate. There is a care package from Onur sitting in kent to finish up the rear brakes, radiator and cooling system. We also have the rest of the parts to finish the clutch and our mechanic has the transfer case finished and is currently resealing tranny. We are slowly inching forward but definitely making progress.
Thanks Onur. @beno
Over the past year my dad and I have been accumulating parts. One of the challenges with this truck is that alot of parts were missing. @shmukster has been a great help. Thanks to @beno for being patient as I constantly change and add to each order. We have oem clutch parts ready to install. OEM radiator and hoses. OEM rear wheel cylinders and shoes. And an @davework gold cad kit. Game plan is to get this thing running/driving/stopping before any bodywork. Hopefully sooner rather than later.
View attachment 1097014View attachment 1097015View attachment 1097017View attachment 1097018
As you used to say to me all the time, "aren't we there yet".....and your response would be no, but we have come a long way and isn't this fun?
Today I got about an hour and checked some small things off the list. Dug the alternator out of storage, finished torqueing rear shackles and flywheel bolts(to 75 ft lbs). finished cleaning up diff cover nuts and figured out a hold down for modified brake line path. Clutch install, rear brake shoes, and galley plug fix are next in line.
Excellent!
